OctaneRender® 2027.1 Alpha 1
- Elvissuperstar007
- Contact:
When I press this button, the viewport temporarily turns black, showing only a small corner of the scene in the top-left. Then everything displays normally. This literally happens when switching modes, and it only occurs during mode changes.
In the imager node, `P_UPSAMPLE_SOURCE_PERCENTAGE` determines the "source" pixel percentage per side.Elvissuperstar007 wrote: Tue Mar 17, 2026 9:29 am Explain how DLSS works. From my understanding, I should render at a lower resolution and then upscale it to 2K or 4K, while keeping the image sharp and not blurry, especially if we are talking about DLSS 4.5.
Right now, I don’t fully understand it. I tried using DLSS, but rendering actually became slower than without it.
I need a clear explanation or a video showing how to use it properly.
Say you have a viewport resolution of
1024x512, with 66 % configuration, the render engine uses 682x341 film buffer internally.Note that each upscaler backend can have its limitation on the upscaling capability. For the current DLSS we use, if it's set at/below 25%, we will fall back to linearly upscaling.
As for the DLSS swapper, we do not support other versions of DLSS by swapping the dll.
- Elvissuperstar007
- Contact:
Sky Plus - Procedural, Realistic Skies & Atmosphere For Cycles & Eevee
https://www.instagram.com/reels/DPs5LjPDS4v/
Posted 2 test scenes on Facebook.
Looking very nice so far, guys.
Looking forward for next improvements.
Hope videos can show a bit where Real-Time falls short.
https://www.facebook.com/share/p/1GCH4VF2dZ/
https://www.facebook.com/share/p/188VNiYtZs/
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
Does anyone know if we getting multi-GPU for Real Time Pathtracing?
That's actually a great one.
Will make a wish in the "Feature Request" Section. (if not already in)
PS: Feature Request Already there: help by voting
https://render.otoy.com/requests/?qa=665/request-sky-%26-atmosphere-system-for-octane-daylight&show=665#q665
- PolderAnimation
- Contact:
Question about AI Light 2.0.
I noticed that when using AI Light 1.0 over the past year, it does not work very well in scenes with moving lights or where lights turn on and off.
Will AI Light 2.0 handle animated lights better?
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
Can you be more specific? Not really sure what do you mean by does not work very well, is it a speed issue or is it a noise issue?PolderAnimation wrote: Mon Mar 30, 2026 11:14 am Question about AI Light 2.0.
AI light 2.0, despite its name, is a complete overhaul, so it would be behave quite differently.
