"Adjust brightness" is the equivalent to the exposure setting in the imager node.SSmolak wrote:We have all AOV nodes to control Camera Imager settings and Post except Camera Exposure :elsksa wrote:Could you elaborate?SSmolak wrote:I noticed that there is no Exposure control for camera in AOV.
Beauty AOV doesn't include Camera Exposure.
OctaneRender® 2023.1.2
Unfortunately not. It doesn't work in 32bit space so it only simple darker highlights.abstrax wrote: "Adjust brightness" is the equivalent to the exposure setting in the imager node.
It's not possible to tell from your video, but you may be changing the brightness after an SDR node. Try placing the brightness adjustment before any other processing.SSmolak wrote:Unfortunately not. It doesn't work in 32bit space so it only simple darker highlights.abstrax wrote: "Adjust brightness" is the equivalent to the exposure setting in the imager node.
If you are still having issues, send me a simple scene.
It seems that the minimum value for the slider is 0.1 in the C4D plugin. Can you manually type in a value less than that? Other than that, it appears to be working correctly.SSmolak wrote:Unfortunately not. It doesn't work in 32bit space so it only simple darker highlights.abstrax wrote: "Adjust brightness" is the equivalent to the exposure setting in the imager node.
The problem was that I had Adjust Brightness after highlight correction thats flatten image to 8bit. The order is important.karl wrote: It seems that the minimum value for the slider is 0.1 in the C4D plugin. Can you manually type in a value less than that? Other than that, it appears to be working correctly.
Hi, team
Engine crashes when I have Nvlink activated with my 2 x 3090.
Could you please fix that?
Regards,
Regards,
C4D 2026.1 v1.8.2 // Octane 2026.1, <<2 X 3090 + NVlink>>, Windows 11 Pro, X399, AMD TR 2950X, 128 GB RAM, NVIDIA SD 560.94
Octane User since V1 Beta
Due to the float precision issue!?? Lol but no! Because the photon tracing "confirmed" the very good accuracy of caustics of 12M-spp rendered by path tracing kernel - check "5 cycles of number of spp from 1M to 12M (or 12 laps*(2) of 1M-spp)" - HERE.abstrax wrote:We won't change that for the reasons I explained to you multiple times already.
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
NEW ViewSonic XG2431 24"
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
Can you check in device preferences whether you have only one of the two devices enabled for denoising? If that's the case, you should be able to work around this issue by enabling both devices for denoising until this issue is fixed.Kalua wrote:Hi, team
Regards,
It looks like AgfaColor Futura 100,200,400 and Futura II 400 Responses are exactly the same...
They are very similar, but not exactly the same. If you save two image files and compare, you can see that Futura 100 is slightly darker than 200 which is slightly darker than 400, and Futura II 400 is slightly darker than all of those.SSmolak wrote:It looks like AgfaColor Futura 100,200,400 and Futura II 400 Responses are exactly the same...
