oh, no!
Why did you changed that position? It's so far away. I prefere HSV and have tp change that so many times. Or is there a way to set HSV permanent?
Cinema4D version 2021.1.5-(R4) (Stable 2021) 28.06.2022
- LOVEXMEDIA
Awesome new look to the node editor! I came across a bug that crashes C4D at lease for me. If you add a Comment and delete the title and the text comment it will crash. It has happened every time for me.
I am on S26.014, dual 3090, NVidia driver 512.59
Thank you again for your continued support and I appreciate you and the team! You all are amazing!
LoveyDov3
https://www.instagram.com/lvydov3/
i9-10940x [Custom Loop] • 96GB RAM • 2× NVLinkRTX 3090 FE
I'll continue to improve the nodes further, it's just a start for the porting.LOVEXMEDIA wrote:Awesome new look to the node editor! I came across a bug that crashes C4D at lease for me. If you add a Comment and delete the title and the text comment it will crash. It has happened every time for me.
And this is a crash case with new system when no text used. Thanks for reporting, will be fixed for next.
Which bug really? Plase share a sample for showing what you do!anklove wrote:Dont know on which version this bug appeared. Materials with camera projection lose alpha and scales weirdly. When generating UVWs from camera projection everything is okay
I d like to set HSV to default as well if possible!moebius wrote:oh, no!
Here's simple example. There is no alpha with camera projection but when i hit Generate UVW from camera projection everything is okay. But im sure i've used camera projections in octane before.aoktar wrote:Which bug really? Plase share a sample for showing what you do!anklove wrote:Dont know on which version this bug appeared. Materials with camera projection lose alpha and scales weirdly. When generating UVWs from camera projection everything is okay
i7 10700k | Win 10 64 bit | RTX 3090
Ok your problem is about opacity. There is a problem with that since I've added stacked material support for camera mapping. It's destroying the opacity connection for first material. Fixing it for next build.anklove wrote:Here's simple example. There is no alpha with camera projection but when i hit Generate UVW from camera projection everything is okay. But im sure i've used camera projections in octane before.aoktar wrote:Which bug really? Plase share a sample for showing what you do!anklove wrote:Dont know on which version this bug appeared. Materials with camera projection lose alpha and scales weirdly. When generating UVWs from camera projection everything is okay
I can add this option but camera view may not match the output.dynaraton wrote:Very nice update, thank you.
Can we have the "keep upright" option in the Universal Camera like we do in Stand-Alone?
It is a very quick useful feature.
Hi I think I found a small glitch with the UI of the new color node.
- The arrow doesnt indicate that we are pointing down when color is open. It's area is also hard to click, needs very precise clicking.
- Same goes for the sliders in HSV mode. They are a bit difficult to click.
- In HSV if value is set to 0, the other sliders are stuck. This is weird as we need to do very specific clicks in a certain order.
Not major things, just something I noticed while i was doing coloring.
Thanks bud!
screencapture: https://www.dropbox.com/s/xuqj443aojny5 ... e.mkv?dl=0
Thanks bud!
That's ok, Perspective Correction in the Thinlens Camera doesn't either but it does the trick.aoktar wrote:I can add this option but camera view may not match the output.dynaraton wrote:Very nice update, thank you.
Thank you!
Asus Prime Deluxe II : Intel i9-10900 X : 128GB G.Skill 3600 MHz DDR4 RAM : (2) Nvidia RTX TITANs w/ NvLink : Win11 Pro : Latest Cinema4D
