wrong glass material between c4d and standalone
- jayroth2020
Hi Salmon, I suspected something like that. Let's start by removing the scattering node and see if you like the result. Glass is pretty simple overall: use an Octane Specular node, add a very tiny bit of roughness for clear glass (0.001 for example) and set your IOR to 1.52 (which is crown glass). Enable Fake Shadows for architectural glass. I often add a little green tint in the Transmission channel for realism.
i've tried the "architectural glass" from Live DB and the problem still remains. You can see that in the Studio Standalonejayroth2020 wrote:Hi Salmon, I suspected something like that. Let's start by removing the scattering node and see if you like the result. Glass is pretty simple overall: use an Octane Specular node, add a very tiny bit of roughness for clear glass (0.001 for example) and set your IOR to 1.52 (which is crown glass). Enable Fake Shadows for architectural glass. I often add a little green tint in the Transmission channel for realism.
Also don't use this camera setup without baking to keyframes. It's like moving randomly.
I found this mesh is bugging it, looks like faces are with bad ordering. Probably you need to fix this mesh
I have used the plugin DIN 3D to export the geometry from archicad to cinema 4d.
I never had problems to render in c4d but it seems i will have in octane studio standalone.
So i will check the export method from archicad.
Thanks Ahmet. Its not easy to find this kind of failure. I will go deep into this.
- jayroth2020
I disabled the fachadas Vidrio-Claro object, which is the glass, yet I still see these other shapes when I export to Standalone. That indicates there is another object in that same section, which has the material Pintura 21 or Pintura 22 applied. Upon further investigation, I suspect it is one of the objects in Pintura 21 causing the issue. Looking at the meshes in the objects with that material applied, the tesselation of those objects is not ideal. Likely fachadas Pintura-21. I would not be surprised to see an errant point in that object. Usually issues like these are geometry-related.
I have confirmed this by disabling that object and exporting to Standalone again. Bad geometry, which you will need to address. The Mesh Check command in Cinema is helpful for cleaning up these issues. Fortunately, this is a very simple shape, and you should be able to resolve the bad geometry rather quickly.
- jayroth2020
You're welcome. Most CAD systems create data that can give render engines trouble, it's just part of the game.
