OctaneRender 2020.2 LightWave Alpha build 2020.2.0.0
artzgodka
juanjgon wrote:
artzgodka wrote:when using this version on a 2xGTX 1080 ti, I have an LW crash when Octane does denoiser
Do you have the nvidia drivers updated to the latest STUDIO version available?
yes I updated
Win 10_Asus Z9PE-D8 WS_2xXeon E5 2696v2{3.2 GHz per core}_64 GB RAM_Zotac RTX 3090_LW 2020
dmodric
Same here. Crashes as soon as I hit out of core with 3GB or more on mine 2070s 8 GB card. I have to turn off denoising and RTX and then it will maybe work. NVlink doesn't help/doesn't work.
Back to 4.05.
Maybe one day when I buy 24 GB card I will be back. It has been over a year now and my subscription is a waste of money.
__________
AMD3600/X570/64GB/2x2070S
ASUS ROG Strix SCAR 17 G733 AMDRyzen7/64GB/3080 16GB
artzgodka
dmodric wrote:Same here. Crashes as soon as I hit out of core with 3GB or more on mine 2070s 8 GB card. I have to turn off denoising and RTX and then it will maybe work. NVlink doesn't help/doesn't work.
Back to 4.05.
I have problem only this ver. of Octane 2020.2.0.0, on every previous version of Octane, everything works fine and I've been using Octane commercially for 1.5 years
dmodric
It works fine when I have scenes that fit in VRAM, I do architecture work and I have a lot of assets and my scenes are often out of core. Maybe it is something wrong with my config, I don't know. But 4.05 works perfectly.
I would be grateful if someone could share a large scene that works for him in out of core in 2020, so I can test it.
__________
artzgodka
now i am on the RTX 3090 and it works great
pixelsmack
So that's what "nested dielectrics" meant? I thought it was some nodal thing. It's simply having meshes inside meshes with glass type materials? That wasn't possible before? I mean it's cool. Just didn't understand the term.
BorisGoreta
To get EXR image exported correctly I need to check get full HDRI image, but then the normal LW exported render gets the wrong gamma. Is it possible to export full HDRI exr untonemapped and normal 8 but PNG tonemapped image ( as seen in IPR ) in the same render pass ?
juanjgon
pixelsmack wrote:So that's what "nested dielectrics" meant? I thought it was some nodal thing. It's simply having meshes inside meshes with glass type materials? That wasn't possible before? I mean it's cool. Just didn't understand the term.
You have more information about the new features here, including the nested dielectrics:
viewtopic.php?f=15&t=75728
juanjgon
BorisGoreta wrote:To get EXR image exported correctly I need to check get full HDRI image, but then the normal LW exported render gets the wrong gamma. Is it possible to export full HDRI exr untonemapped and normal 8 but PNG tonemapped image ( as seen in IPR ) in the same render pass ?
This is not possible currently because the same option is used for saving and to get the rendered images, but I'll take a look at it to check if it is possible adding a new option to get the tonemmaped 8bit data.
promity
I found a problem with Displacement:
https://youtu.be/PEi2Oljnimw
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
