OctaneRender 2020.2 LightWave Alpha build 2020.2.0.0
Forums: OctaneRender 2020.2 LightWave Alpha build 2020.2.0.0
Re: OctaneRender 2020.2 LightWave Alpha build 2020.2.0.0
Postby artzgodka » Tue Jan 05, 2021 7:59 pm
artzgodka Tue Jan 05, 2021 7:59 pm
juanjgon wrote:
artzgodka wrote:when using this version on a 2xGTX 1080 ti, I have an LW crash when Octane does denoiser
Do you have the nvidia drivers updated to the latest STUDIO version available?
yes I updated
Win 10_Asus Z9PE-D8 WS_2xXeon E5 2696v2{3.2 GHz per core}_64 GB RAM_Zotac RTX 3090_LW 2020
artzgodka
Postby dmodric » Tue Jan 05, 2021 11:29 pm
dmodric Tue Jan 05, 2021 11:29 pm
Same here. Crashes as soon as I hit out of core with 3GB or more on mine 2070s 8 GB card. I have to turn off denoising and RTX and then it will maybe work. NVlink doesn't help/doesn't work.
Back to 4.05.
Maybe one day when I buy 24 GB card I will be back. It has been over a year now and my subscription is a waste of money.
__________
AMD3600/X570/64GB/2x2070S
ASUS ROG Strix SCAR 17 G733 AMDRyzen7/64GB/3080 16GB
dmodric
Postby artzgodka » Wed Jan 06, 2021 8:42 am
artzgodka Wed Jan 06, 2021 8:42 am
dmodric wrote:Same here. Crashes as soon as I hit out of core with 3GB or more on mine 2070s 8 GB card. I have to turn off denoising and RTX and then it will maybe work. NVlink doesn't help/doesn't work.
Back to 4.05.
I have problem only this ver. of Octane 2020.2.0.0, on every previous version of Octane, everything works fine and I've been using Octane commercially for 1.5 years
artzgodka
Postby dmodric » Wed Jan 06, 2021 10:18 am
dmodric Wed Jan 06, 2021 10:18 am
It works fine when I have scenes that fit in VRAM, I do architecture work and I have a lot of assets and my scenes are often out of core. Maybe it is something wrong with my config, I don't know. But 4.05 works perfectly.
I would be grateful if someone could share a large scene that works for him in out of core in 2020, so I can test it.
__________
dmodric
Postby artzgodka » Fri Jan 08, 2021 7:35 pm
artzgodka Fri Jan 08, 2021 7:35 pm
now i am on the RTX 3090 and it works great
artzgodka
Postby pixelsmack » Mon Jan 11, 2021 11:50 pm
pixelsmack Mon Jan 11, 2021 11:50 pm
So that's what "nested dielectrics" meant? I thought it was some nodal thing. It's simply having meshes inside meshes with glass type materials? That wasn't possible before? I mean it's cool. Just didn't understand the term.
pixelsmack
Tonemapped and untonemapped EXR
Postby BorisGoreta » Tue Jan 12, 2021 4:03 pm
BorisGoreta Tue Jan 12, 2021 4:03 pm
To get EXR image exported correctly I need to check get full HDRI image, but then the normal LW exported render gets the wrong gamma. Is it possible to export full HDRI exr untonemapped and normal 8 but PNG tonemapped image ( as seen in IPR ) in the same render pass ?
BorisGoreta
Postby juanjgon » Tue Jan 12, 2021 10:33 pm
juanjgon Tue Jan 12, 2021 10:33 pm
pixelsmack wrote:So that's what "nested dielectrics" meant? I thought it was some nodal thing. It's simply having meshes inside meshes with glass type materials? That wasn't possible before? I mean it's cool. Just didn't understand the term.
You have more information about the new features here, including the nested dielectrics:
viewtopic.php?f=15&t=75728
juanjgon
Re: Tonemapped and untonemapped EXR
Postby juanjgon » Wed Jan 13, 2021 12:37 pm
juanjgon Wed Jan 13, 2021 12:37 pm
BorisGoreta wrote:To get EXR image exported correctly I need to check get full HDRI image, but then the normal LW exported render gets the wrong gamma. Is it possible to export full HDRI exr untonemapped and normal 8 but PNG tonemapped image ( as seen in IPR ) in the same render pass ?
This is not possible currently because the same option is used for saving and to get the rendered images, but I'll take a look at it to check if it is possible adding a new option to get the tonemmaped 8bit data.
juanjgon
Postby promity » Thu Jan 28, 2021 3:00 am
promity Thu Jan 28, 2021 3:00 am
I found a problem with Displacement:
https://youtu.be/PEi2Oljnimw
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
promity
PreviousNext
Return to Releases
Tue Jun 04, 2024 12:53 pm [ UTC ]
