yes I updatedjuanjgon wrote:Do you have the nvidia drivers updated to the latest STUDIO version available?artzgodka wrote:when using this version on a 2xGTX 1080 ti, I have an LW crash when Octane does denoiser
OctaneRender 2020.2 LightWave Alpha build 2020.2.0.0
Win 10_Asus Z9PE-D8 WS_2xXeon E5 2696v2{3.2 GHz per core}_64 GB RAM_Zotac RTX 3090_LW 2020
						Same here. Crashes as soon as I hit out of core with 3GB or more on mine 2070s 8 GB card. I have to turn off denoising and RTX and then it will maybe work. NVlink doesn't help/doesn't work.
Back to 4.05.
Maybe one day when I buy 24 GB card I will be back. It has been over a year now and my subscription is a waste of money.
							Back to 4.05.
__________
AMD3600/X570/64GB/2x2070S
ASUS ROG Strix SCAR 17 G733 AMDRyzen7/64GB/3080 16GB
I have problem only this ver. of Octane 2020.2.0.0, on every previous version of Octane, everything works fine and I've been using Octane commercially for 1.5 yearsdmodric wrote:Same here. Crashes as soon as I hit out of core with 3GB or more on mine 2070s 8 GB card. I have to turn off denoising and RTX and then it will maybe work. NVlink doesn't help/doesn't work.
Back to 4.05.
						It works fine when I have scenes that fit in VRAM, I do architecture work and I have a lot of assets and my scenes are often out of core. Maybe it is something wrong with my config, I don't know. But 4.05 works perfectly.
I would be grateful if someone could share a large scene that works for him in out of core in 2020, so I can test it.
__________
now i am on the RTX 3090 and it works great
						- pixelsmack
So that's what "nested dielectrics" meant? I thought it was some nodal thing. It's simply having meshes inside meshes with glass type materials? That wasn't possible before? I mean it's cool. Just didn't understand the term.
						- BorisGoreta
 - Contact:
To get EXR image exported correctly I need to check get full HDRI image, but then the normal LW exported render gets the wrong gamma. Is it possible to export full HDRI exr untonemapped and normal 8 but PNG tonemapped image ( as seen in IPR ) in the same render pass ?
						You have more information about the new features here, including the nested dielectrics:pixelsmack wrote:So that's what "nested dielectrics" meant? I thought it was some nodal thing. It's simply having meshes inside meshes with glass type materials? That wasn't possible before? I mean it's cool. Just didn't understand the term.
viewtopic.php?f=15&t=75728
This is not possible currently because the same option is used for saving and to get the rendered images, but I'll take a look at it to check if it is possible adding a new option to get the tonemmaped 8bit data.BorisGoreta wrote:To get EXR image exported correctly I need to check get full HDRI image, but then the normal LW exported render gets the wrong gamma. Is it possible to export full HDRI exr untonemapped and normal 8 but PNG tonemapped image ( as seen in IPR ) in the same render pass ?
I found a problem with Displacement:
https://youtu.be/PEi2Oljnimw
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
						Lightwave 3d
