Houdini crash at saving file Octane 2018.1.0.3
Houdini Integrated Plugin
juanjgon
What a weird issue! Can you please send me a new log again? I want to be sure that the crash happens always at the same point.
dotcom
i've noticed 2 things :
rendering an exr : no crash
rendering a png : crash
i've tried rendering a simple scene : it renders
> but in the png format : the image looks buggy (vertical lines) see the jpg attached to this message.
> whereas for exr option the exr image rendered is right.
png render
png render
________________________________
dotcom
Here a two octane log
the one in exr format which is not crashing houdini
and the one with png which does crashing houdini.
no-crash_exr-render_octane_log.txt
no crash exr
(4.25 KiB) Downloaded 306 times
crash_png-render_octane_log.txt
crash png
(4.05 KiB) Downloaded 321 times
dotcom
Okay,
Render status ok, no crash :
EXR render : Pathtracing I 25 sples I Adaptive Sampling on I AI light on I Denoising on I Motion Blur on : camera MB, Objects MB, Lights MB, Deformation MB
I have enable the trail sops to compute velocity and it still renders.
then tried to up the samples (step by step.... i put more stuff into it to be sure)
EXR render : Pathtracing I 1000 sples I Adaptive Sampling on I AI light on I Denoising on I Motion Blur on : camera MB, Objects MB, Lights MB, Deformation MB
juanjgon
Ok. So Octane only crashes if you try to save a PNG file, right? One question, have you tried the latest build released this week?
viewtopic.php?f=102&t=70914
I ask because really I can't reproduce this problem here, and I don't have any other report about a problem like that. I wonder if the problem could even be related to the filename ... if the latest build still crashes, can you please check this filename?
$HIP/render/test_$F4
dotcom
The image is rendering but not saving :
what does this means : External WM_DESTROY received for QWidgetWindow ?
17:46:07 ERROR: [materials] --------- Material SHOP node "" not found
17:46:08 INFOR: [loader] ------------ Transformation matrix for MB step 0
17:46:08 INFOR: [loader] ------------ Transformation matrix for MB step 1
17:46:08 INFOR: [loader] ------------ Building the render target
17:46:08 ERROR: [rt vop] ------------ The Octane node has not been found in the linked node
17:46:08 INFOR: [loader] ------------ Loading the Houdini camera parameters
17:46:08 INFOR: [loader] ------------ Houdini camera path: /obj/cam2
17:46:08 INFOR: [loader] ------------ Scene Loaded
17:46:08 INFOR: [loader] ------------ Setting the motion blur parameters
17:46:08 INFOR: [render] ------------ Render setup, set renderTarget and update
17:46:34 INFOR: [render progress] --- 1 percent, Samples 1 of 100, R.Time 00:00:04, MSamples/Sec. 0.51
17:46:40 INFOR: [render progress] --- 2 percent, Samples 2 of 100, R.Time 00:00:10, MSamples/Sec. 0.50
17:46:40 INFOR: [render progress] --- 3 percent, Samples 3 of 100, R.Time 00:00:10, MSamples/Sec. 0.78
17:46:45 INFOR: [render progress] --- 7 percent, Samples 7 of 100, R.Time 00:00:14, MSamples/Sec. 1.75
17:46:48 INFOR: [render progress] --- 10 percent, Samples 10 of 100, R.Time 00:00:17, MSamples/Sec. 1.82
17:46:50 INFOR: [render progress] --- 16 percent, Samples 16 of 100, R.Time 00:00:20, MSamples/Sec. 3.67
17:46:54 INFOR: [render progress] --- 32 percent, Samples 32 of 100, R.Time 00:00:24, MSamples/Sec. 6.53
17:47:00 INFOR: [render progress] --- 48 percent, Samples 48 of 100, R.Time 00:00:30, MSamples/Sec. 7.11
17:47:05 INFOR: [render progress] --- 64 percent, Samples 64 of 100, R.Time 00:00:35, MSamples/Sec. 7.11
17:47:11 INFOR: [render progress] --- 80 percent, Samples 80 of 100, R.Time 00:00:41, MSamples/Sec. 7.09
17:47:17 INFOR: [render progress] --- 96 percent, Samples 96 of 100, R.Time 00:00:47, MSamples/Sec. 7.06
17:47:17 INFOR: [render progress] --- 97 percent, Samples 97 of 100, R.Time 00:00:47, MSamples/Sec. 0.00
17:47:20 INFOR: [render progress] --- 100 percent, Samples 100 of 100, R.Time 00:00:47, MSamples/Sec. 0.00
17:47:21 INFOR: [render stats] ------ Objects: 4, Triangles: 13743020, Hairs: 0, Voxels: 0, Particles: 0
17:47:21 INFOR: [render stats] ------ Textures (8/16/32/64): 0 / 0 / 0 / 2
17:47:21 INFOR: [render stats] ------ GPU RAM (used/free/total): 4584 / 4441/ 11264 [MB]
17:47:21 INFOR: [render stats] ------ Sys RAM (used/free): 34726 / 130971, Total mem. used: 23658 [MB]
17:47:21 INFOR: [render stats] ------ Out-of-core RAM (used/max) 0 / 16384 [MB]
17:47:21 INFOR: [render stats] ------ Local GPUs: 4, Net GPUs: 0, Net memory: 0 [MB]
17:47:21 INFOR: [save image] -------- Save image function enabled
17:47:21 INFOR: [save image] -------- Saving the "Denoised beauty" pass to the "E:/PERSO/VFX_SCHOOL/WEEK-1/week_1_01/render/week-1-exercise2-7.Octane_ROP1-7.0120" file
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x61e2df9d20, name="RE_WindowWindow") , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x5fad16c820, name="RE_WindowWindow") , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x30cdf4c9a0, name="RE_WindowWindow") , parent: QWindow(0x0) , transient parent: QWindow(0x0)
juanjgon
I'm not sure. This is a Houdini warning. Currently the Octane plugin is not using Qt at all ...
Have you tried the latest plugin build, or changing the file name?
dotcom
okay got no more errors now
the previous error was due to empty geo (a controller for the cam position), so adding a cube in it but disabling visibility resolves this.
BUT STILL, i don't know why but the file is not saved
18:14:02 INFOR: [save image] -------- Save image function enabled
18:14:02 INFOR: [save image] -------- Saving the "Denoised beauty" pass to the "E:/PERSO/VFX_SCHOOL/WEEK-1/week_1_01/render/week-1-exercise2-7.Octane_ROP1-7.0250" file
the log files says the opposite, so i don't see what's the solution,
Thank you JaunJgon,
juanjgon
Please, changes the prefix filename. Perhaps somehow Octane has a problem with your current filename ... can you please try this one?
dotcom
seems like " $F4 " is not working : the image number is not implemented into final image file name
Return to “Houdini”
