What a weird issue! Can you please send me a new log again? I want to be sure that the crash happens always at the same point.
Houdini crash at saving file Octane 2018.1.0.3
i've noticed 2 things :
rendering an exr : no crash
rendering a png : crash
i've tried rendering a simple scene : it renders
> but in the png format : the image looks buggy (vertical lines) see the jpg attached to this message.
> whereas for exr option the exr image rendered is right.
________________________________
Here a two octane log
the one in exr format which is not crashing houdini
and the one with png which does crashing houdini.
- no-crash_exr-render_octane_log.txt
- no crash exr
- (4.25 KiB) Downloaded 303 times
- crash_png-render_octane_log.txt
- crash png
- (4.05 KiB) Downloaded 315 times
Okay,
Render status ok, no crash :
EXR render : Pathtracing I 25 sples I Adaptive Sampling on I AI light on I Denoising on I Motion Blur on : camera MB, Objects MB, Lights MB, Deformation MB
I have enable the trail sops to compute velocity and it still renders.
then tried to up the samples (step by step.... i put more stuff into it to be sure)
EXR render : Pathtracing I 1000 sples I Adaptive Sampling on I AI light on I Denoising on I Motion Blur on : camera MB, Objects MB, Lights MB, Deformation MB
Ok. So Octane only crashes if you try to save a PNG file, right? One question, have you tried the latest build released this week?
viewtopic.php?f=102&t=70914
I ask because really I can't reproduce this problem here, and I don't have any other report about a problem like that. I wonder if the problem could even be related to the filename ... if the latest build still crashes, can you please check this filename?
$HIP/render/test_$F4-Juanjo
The image is rendering but not saving :
what does this means : External WM_DESTROY received for QWidgetWindow ?
17:46:07 ERROR: [materials] --------- Material SHOP node "" not found
17:46:08 INFOR: [loader] ------------ Transformation matrix for MB step 0
17:46:08 INFOR: [loader] ------------ Transformation matrix for MB step 1
17:46:08 INFOR: [loader] ------------ Building the render target
17:46:08 ERROR: [rt vop] ------------ The Octane node has not been found in the linked node
17:46:08 INFOR: [loader] ------------ Loading the Houdini camera parameters
17:46:08 INFOR: [loader] ------------ Houdini camera path: /obj/cam2
17:46:08 INFOR: [loader] ------------ Scene Loaded
17:46:08 INFOR: [loader] ------------ Setting the motion blur parameters
17:46:08 INFOR: [render] ------------ Render setup, set renderTarget and update
17:46:34 INFOR: [render progress] --- 1 percent, Samples 1 of 100, R.Time 00:00:04, MSamples/Sec. 0.51
17:46:40 INFOR: [render progress] --- 2 percent, Samples 2 of 100, R.Time 00:00:10, MSamples/Sec. 0.50
17:46:40 INFOR: [render progress] --- 3 percent, Samples 3 of 100, R.Time 00:00:10, MSamples/Sec. 0.78
17:46:45 INFOR: [render progress] --- 7 percent, Samples 7 of 100, R.Time 00:00:14, MSamples/Sec. 1.75
17:46:48 INFOR: [render progress] --- 10 percent, Samples 10 of 100, R.Time 00:00:17, MSamples/Sec. 1.82
17:46:50 INFOR: [render progress] --- 16 percent, Samples 16 of 100, R.Time 00:00:20, MSamples/Sec. 3.67
17:46:54 INFOR: [render progress] --- 32 percent, Samples 32 of 100, R.Time 00:00:24, MSamples/Sec. 6.53
17:47:00 INFOR: [render progress] --- 48 percent, Samples 48 of 100, R.Time 00:00:30, MSamples/Sec. 7.11
17:47:05 INFOR: [render progress] --- 64 percent, Samples 64 of 100, R.Time 00:00:35, MSamples/Sec. 7.11
17:47:11 INFOR: [render progress] --- 80 percent, Samples 80 of 100, R.Time 00:00:41, MSamples/Sec. 7.09
17:47:17 INFOR: [render progress] --- 96 percent, Samples 96 of 100, R.Time 00:00:47, MSamples/Sec. 7.06
17:47:17 INFOR: [render progress] --- 97 percent, Samples 97 of 100, R.Time 00:00:47, MSamples/Sec. 0.00
17:47:20 INFOR: [render progress] --- 100 percent, Samples 100 of 100, R.Time 00:00:47, MSamples/Sec. 0.00
17:47:21 INFOR: [render stats] ------ Objects: 4, Triangles: 13743020, Hairs: 0, Voxels: 0, Particles: 0
17:47:21 INFOR: [render stats] ------ Textures (8/16/32/64): 0 / 0 / 0 / 2
17:47:21 INFOR: [render stats] ------ GPU RAM (used/free/total): 4584 / 4441/ 11264 [MB]
17:47:21 INFOR: [render stats] ------ Sys RAM (used/free): 34726 / 130971, Total mem. used: 23658 [MB]
17:47:21 INFOR: [render stats] ------ Out-of-core RAM (used/max) 0 / 16384 [MB]
17:47:21 INFOR: [render stats] ------ Local GPUs: 4, Net GPUs: 0, Net memory: 0 [MB]
17:47:21 INFOR: [save image] -------- Save image function enabled
17:47:21 INFOR: [save image] -------- Saving the "Denoised beauty" pass to the "E:/PERSO/VFX_SCHOOL/WEEK-1/week_1_01/render/week-1-exercise2-7.Octane_ROP1-7.0120" file
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x61e2df9d20, name="RE_WindowWindow") , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x5fad16c820, name="RE_WindowWindow") , parent: QWindow(0x0) , transient parent: QWindow(0x0)
Qt Warn: External WM_DESTROY received for QWidgetWindow(0x30cdf4c9a0, name="RE_WindowWindow") , parent: QWindow(0x0) , transient parent: QWindow(0x0)
okay got no more errors now
the previous error was due to empty geo (a controller for the cam position), so adding a cube in it but disabling visibility resolves this.
BUT STILL, i don't know why but the file is not saved
18:14:02 INFOR: [save image] -------- Save image function enabled
18:14:02 INFOR: [save image] -------- Saving the "Denoised beauty" pass to the "E:/PERSO/VFX_SCHOOL/WEEK-1/week_1_01/render/week-1-exercise2-7.Octane_ROP1-7.0250" file
the log files says the opposite, so i don't see what's the solution,
Thank you JaunJgon,
Thank you JaunJgon,
seems like " $F4 " is not working : the image number is not implemented into final image file name
