How to do SSS on Max ?!
paride4331
Hi Fabrice,
you have to set density in scattering node.
Here un basic sss material made with diffuse material.
Regards
Paride
foam.rar
(151.6 KiB) Downloaded 176 times
Fabrice
Thanks Paride!
It's much simpler with a diffuse mat than with a spec mat :)
Octane 3.04.5 + 3DS Max 2014 plugin (GTX 980 Ti + GTX 780)
Fabrice
I'm still playing with density but it has allmost no effects.
From 1 to 150 I barely see no changes...
The light should be massively changing to the corner because of the thickness varying...
PS : And another topic, how to make slight reflection on that ?
paride4331
Hi Fabrice,
You should not miss light and transmission.
About the reflection, you may use a material mix, if it can be enough, otherwise you have to use a specular material.
Regards
Paride
Return to “Autodesk 3Ds Max”
