I checked your scene and Roeland's portal fix also fixes the performance difference.smicha wrote:abstrax wrote:Obviously, scenes should render the same between versions. There should also be no dramatic speed changes, but without an example scene showing the problem, we can't say much more. Obviously, the tests we ran before we release didn't show any issues.
-> Please post/send us any example scenes and we will investigate as soon as possible.
So I see this is due to portals
viewtopic.php?f=24&t=57372&start=10#p295814
3.03 vs 3.04 - massive speed drop in PT - WHY?
abstrax wrote:I checked your scene and Roeland's portal fix also fixes the performance difference.smicha wrote:abstrax wrote:Obviously, scenes should render the same between versions. There should also be no dramatic speed changes, but without an example scene showing the problem, we can't say much more. Obviously, the tests we ran before we release didn't show any issues.
Is the fix available now?
Not yet, but currently, everything points to another release tomorrow.smicha wrote:abstrax wrote: I checked your scene and Roeland's portal fix also fixes the performance difference.
abstrax wrote:Not yet, but currently, everything points to another release tomorrow.smicha wrote:abstrax wrote: I checked your scene and Roeland's portal fix also fixes the performance difference.
Thank you.
...and the exposure issue between versions, has anyone else reported it?abstrax wrote:Obviously, scenes should render the same between versions. There should also be no dramatic speed changes, but without an example scene showing the problem, we can't say much more. Obviously, the tests we ran before we release didn't show any issues.
(The scene in question is a client work product and I can't share it unfortunately).
Ryzen 5800x at 4.4GHz | 32GB | 1 x 3090 ti | 1 x RTX 2080 ti
The portal problem might also affect brightness in general. Do yo use the Standalone or some plugin? If it's the latter: There has been a bug fix in 3.04 that sets the distribution brightness of emitters to 1 in case the distribution pin is not connected. In the past (due to an oversight) a distribution texture of 0.7 would have been applied in this case. The Standalone converts older scenes accordingly, but plugins may have a different behaviour.Godstrike wrote:...and the exposure issue between versions, has anyone else reported it?abstrax wrote:Obviously, scenes should render the same between versions. There should also be no dramatic speed changes, but without an example scene showing the problem, we can't say much more. Obviously, the tests we ran before we release didn't show any issues.
I use the LW plugin, which exhibited the brightness issue, and then also exported an orbx file which also had the same issue.abstrax wrote:The portal problem might also affect brightness in general. Do yo use the Standalone or some plugin? If it's the latter: There has been a bug fix in 3.04 that sets the distribution brightness of emitters to 1 in case the distribution pin is not connected. In the past (due to an oversight) a distribution texture of 0.7 would have been applied in this case. The Standalone converts older scenes accordingly, but plugins may have a different behaviour.Godstrike wrote:...and the exposure issue between versions, has anyone else reported it?abstrax wrote:Obviously, scenes should render the same between versions. There should also be no dramatic speed changes, but without an example scene showing the problem, we can't say much more. Obviously, the tests we ran before we release didn't show any issues.
I just tested new 3.04.5 and speed is comparable to 3.03.04 now.
Thank you!
Thank you!
