3.03 vs 3.04 - massive speed drop in PT - WHY?
Forums: 3.03 vs 3.04 - massive speed drop in PT - WHY?
Re: 3.03 vs 3.04 - massive speed drop in PT - WHY?
Postby abstrax » Wed Nov 23, 2016 11:43 pm
abstrax Wed Nov 23, 2016 11:43 pm
smicha wrote:
abstrax wrote:Obviously, scenes should render the same between versions. There should also be no dramatic speed changes, but without an example scene showing the problem, we can't say much more. Obviously, the tests we ran before we release didn't show any issues.
-> Please post/send us any example scenes and we will investigate as soon as possible.
So I see this is due to portals
viewtopic.php?f=24&t=57372&start=10#p295814
I checked your scene and Roeland's portal fix also fixes the performance difference.
abstrax
Postby smicha » Thu Nov 24, 2016 12:04 am
smicha Thu Nov 24, 2016 12:04 am
Is the fix available now?
smicha
Postby abstrax » Thu Nov 24, 2016 12:17 am
abstrax Thu Nov 24, 2016 12:17 am
smicha wrote:
abstrax wrote:I checked your scene and Roeland's portal fix also fixes the performance difference.
Not yet, but currently, everything points to another release tomorrow.
abstrax
Postby smicha » Thu Nov 24, 2016 1:12 am
smicha Thu Nov 24, 2016 1:12 am
Thank you.
smicha
Postby Godstrike » Thu Nov 24, 2016 12:20 pm
Godstrike Thu Nov 24, 2016 12:20 pm
...and the exposure issue between versions, has anyone else reported it?
(The scene in question is a client work product and I can't share it unfortunately).
Ryzen 5800x at 4.4GHz | 32GB | 2 x RTX 2080 ti | 1 x GTX 1070 ti| 1 x GTX 1060 6GB | 1 x 1GB SSD M.2 | 1 x 500GB SSD | 2TB WD BLACK | Windows 10 64
Godstrike
Postby abstrax » Thu Nov 24, 2016 7:55 pm
abstrax Thu Nov 24, 2016 7:55 pm
The portal problem might also affect brightness in general. Do yo use the Standalone or some plugin? If it's the latter: There has been a bug fix in 3.04 that sets the distribution brightness of emitters to 1 in case the distribution pin is not connected. In the past (due to an oversight) a distribution texture of 0.7 would have been applied in this case. The Standalone converts older scenes accordingly, but plugins may have a different behaviour.
abstrax
Postby Godstrike » Fri Nov 25, 2016 11:07 am
Godstrike Fri Nov 25, 2016 11:07 am
I use the LW plugin, which exhibited the brightness issue, and then also exported an orbx file which also had the same issue.
Godstrike
Postby smicha » Fri Nov 25, 2016 1:36 pm
smicha Fri Nov 25, 2016 1:36 pm
I just tested new 3.04.5 and speed is comparable to 3.03.04 now.
Thank you!
smicha
Previous
Return to Commercial Product News & Releases (Download here)
Sun Jun 16, 2024 5:15 pm [ UTC ]
