OctaneRender™ 3.0 for LightWave™ - Production build 3.00
vipvip
i try this right now
thanks
vipvip
OK, i've done again the full installation after restauring with true-image and it works : it seems it is my fault : i didn't replace the old residual TBB.DLL coming from an old alpha version...
Sorry for this alert and thanks a lot for your near real-time help (as usual ;) )
juanjgon
No problem, thanks!
BorisGoreta
Is it possible for TFD not to cast illumination but to render the light source (fire) ?
Is it necessary to have full scene update for TFD animation to render properly ?
juanjgon
BorisGoreta wrote:Is it possible for TFD not to cast illumination but to render the light source (fire) ?
I think that you should be able to disable the illumination casting if you disable the "Cast illumination" option in the emission node. Doesn't work for volumetrics?
Yep, currently you need to full reload the scene to render animated volumetrics. I'll check if it is possible work with them in update more in a future version.
BorisGoreta
"Cast Illumination" does not work with volumes, it always casts it.
Return to “Lightwave 3D”
