i try this right now
thanks
						OctaneRender™ 3.0 for LightWave™ - Production build 3.00
OK, i've done again the full installation after restauring with true-image and it works : it seems it is my fault : i didn't replace the old residual TBB.DLL coming from an old alpha version...
Sorry for this alert and thanks a lot for your near real-time help (as usual
- BorisGoreta
 - Contact:
Is it  possible for TFD not to cast illumination but to render the light source (fire) ?
Is it necessary to have full scene update for TFD animation to render properly ?
I think that you should be able to disable the illumination casting if you disable the "Cast illumination" option in the emission node. Doesn't work for volumetrics?BorisGoreta wrote:Is it possible for TFD not to cast illumination but to render the light source (fire) ?
Yep, currently you need to full reload the scene to render animated volumetrics. I'll check if it is possible work with them in update more in a future version.
- BorisGoreta
 - Contact:
"Cast Illumination" does not work with volumes, it always casts it.
