THANKS!
working perfectly now.
Non-offical Blender 2.56 plugin
New animation test with updated v0.3 script (download from first post)
Workflow:
- render still image (with option 'Overwrite' ocs if needed)
- setup scene, material nodes, etc... in Octane then save on quit
- make sure option 'Overwrite ocs' is disabled
- render anim
Attached is a quick emitting particles anim + screenshot.
Bonus: hair-particles still-rendering
Workflow:
- render anim
- Attachments
- part2.mpg.zip
- (771.79 KiB) Downloaded 395 times
Desktop: Ubuntu 13.04 x64 - i7-3770K @ 3.5GHz - 32GB DDR3 - GTX670 2048MB
Laptop: Linux Mint 11 x64 - i7-2860QM @ 2.5GHz - 16GB DDR3 - Quadro 3000M 2GB
Software: NVidia 319.12 - Cuda 4.2.9 - Blender 2.66a
- SamCameron
To be honest I don't think the way it works the particle system to render in Octane is a solution, cause in my tests using the Particle Instancer Modifier is far from a good solution, it's a very heavy process all the time, even when exports to Octane, require a lot of time of exporting and importing into Octane. Octane Render should read the meshes directly from the scene as Blender does without having to use the particle instancer modifier.
- SamCameron
Please, can you tell me how to render these bullets? cause even with the particle instancer I cannot render the meshes where they should be, it appears in a different possition (related to the original mesh).
- Attachments
- particletest4.zip
- (638.22 KiB) Downloaded 379 times
You must apply transforms (rotation scale and location) to the object otherwise modifers apply on the 'original'. This is why you didn't get the expected result. This rule applies for most of the modifiers, not only the particle one.
If you want to improve performance during modeling, you should use less polygons and use modifers. I've replaced your bullet in the second file so you can compare the smoothness in Blender. Exporting frame #169 to Octane gave me this:
- original mesh 38 secs to export, 605440 triangles in Octane
- simple mesh + subsurface level 2, 29 secs to export, 699012 triangles in Octane.
I've setup the modifer in both blend files so you can compare with the original. I also tweaked the render/display part of the particle system itself.
- Attachments
- particletest4.blend.zip
- (644.41 KiB) Downloaded 431 times
- particletest4bis.blend.zip
- (415.78 KiB) Downloaded 423 times
i love the script! dont got to use 2.49 anymore!!
2.56 script works great for me under ubuntu64/osx/winxp!
thanks a lot yoyoz!
thanks a lot yoyoz!
- Mint 10 64bit nvidia drv 260.19.29/cudatoolkit3.0 intel q6600, 4gbRAM, GTX470 1,2GB
- Mint 10 64bit/ Win7 64bit nvidia drv 260.19.29/cudatoolkit3.2 amd X6, 16gbRAM, 2x GTX580 3GB
->Octane 2.44/ Blender2.5x
- mib2berlin
@r0ug3r, i downloaded yesterday without problems, may a mail to the support guy´s?
Btw. the plugin works fine here for me, thank you.
Cheers mib
Cheers mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
