OctaneRender® for Maya® 2.11.1 - 5.6 Linux [OBSOLETE]
This seems to be an issue not only affecting octane for maya (at least here on our machine running a K6000)
I will check some more configurations and make sure the driver works correct and wil come back with some more information.
lspci -v | NVIDIA
VGA compatible controller: NVIDIA Corporation GK110GL [Quadro K6000] (rev a1) (prog-if 00 [VGA controller])
Subsystem: NVIDIA Corporation Device 1036
Flags: bus master, fast devsel, latency 0, IRQ 118
Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at d000 [size=128]
[virtual] Expansion ROM at fb000000 [disabled] [size=512K]
Capabilities: <access denied>
Kernel driver in use: nvidiaCode: Select all
dpkg -l | grep nvidia
ii nvidia-340 amd64 NVIDIA binary driver - version 340.46
ii nvidia-340-dev amd64 NVIDIA binary Xorg driver development files
ii nvidia-340-uvm amd64 NVIDIA Unified Memory kernel module
ii nvidia-cuda-dev amd64 NVIDIA CUDA development files
ii nvidia-cuda-doc all NVIDIA CUDA and OpenCL documentation
ii nvidia-cuda-gdb amd64 NVIDIA CUDA GDB
ii nvidia-cuda-toolkit amd64 NVIDIA CUDA toolkit
ii nvidia-opencl-icd-340 amd64 NVIDIA OpenCL ICD
ii nvidia-prime amd64 Tools to enable NVIDIA's Prime
ii nvidia-profiler amd64 NVIDIA Profiler for CUDA and OpenCL
ii nvidia-settings amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-visual-profiler- stratified
Do you know the exact version of the driver (never mind I see you're using 340.46)? I'm using Ubuntu 14.04 with 340.24 - I always download the drivers directly from the NVIDIA website and avoid those that come from the package manager. NVIDIA drivers on Linux can be problematic and some driver versions are known to cause grief.
cheers,
Thomas
cheers,
Thomas
