OctaneRender® for Maya® 2.11.1 - 5.6 Linux [OBSOLETE]
Moderator: JimStar
JimStar
Are you sure some other renderer does not use the CUDA resources? VRay RT for example?..
JohnMesh
This seems to be an issue not only affecting octane for maya (at least here on our machine running a K6000)
lspci -v | NVIDIA
        VGA compatible controller: NVIDIA Corporation GK110GL [Quadro K6000] (rev a1) (prog-if 00 [VGA controller])
        Subsystem: NVIDIA Corporation Device 1036
        Flags: bus master, fast devsel, latency 0, IRQ 118
        Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
        Memory at e0000000 (64-bit, prefetchable) [size=256M]
        Memory at f0000000 (64-bit, prefetchable) [size=32M]
        I/O ports at d000 [size=128]
        [virtual] Expansion ROM at fb000000 [disabled] [size=512K]
        Capabilities: <access denied>
        Kernel driver in use: nvidia
dpkg -l | grep nvidia
ii  nvidia-340                                                  amd64        NVIDIA binary driver - version 340.46
ii  nvidia-340-dev                                              amd64        NVIDIA binary Xorg driver development files
ii  nvidia-340-uvm                                              amd64        NVIDIA Unified Memory kernel module
ii  nvidia-cuda-dev                                             amd64        NVIDIA CUDA development files
ii  nvidia-cuda-doc                                             all          NVIDIA CUDA and OpenCL documentation
ii  nvidia-cuda-gdb                                             amd64        NVIDIA CUDA GDB
ii  nvidia-cuda-toolkit                                         amd64        NVIDIA CUDA toolkit
ii  nvidia-opencl-icd-340                                       amd64        NVIDIA OpenCL ICD
ii  nvidia-prime                                                amd64        Tools to enable NVIDIA's Prime
ii  nvidia-profiler                                             amd64        NVIDIA Profiler for CUDA and OpenCL
ii  nvidia-settings                                             amd64        Tool for configuring the NVIDIA graphics driver
ii  nvidia-visual-profiler
I will check some more configurations and make sure the driver works correct and wil come back with some more information.
stratified
Do you know the exact version of the driver (never mind I see you're using 340.46)? I'm using Ubuntu 14.04 with 340.24 - I always download the drivers directly from the NVIDIA website and avoid those that come from the package manager. NVIDIA drivers on Linux can be problematic and some driver versions are known to cause grief.
cheers,
Thomas
JohnMesh
We solved it, it seems like the nvidia driver was messed up. Completey removing and reinstalling solved this.
JimStar
Next version HERE.
Return to “Autodesk Maya”
