OctaneRender® for Maya® 2.11.1 - 5.6 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2015 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • Switched to Maya 2015 ext1 sp5 for Linux.
  • Few minor fixes.
Installation:
DOWNLOAD
OctaneRender for Maya - v5.6 Linux (16.8MB autoinstaller file)
Yours,
The OctaneRender™ Team.
JohnMesh
Thanks for this update.
Im running into the same error massage:
// Error: line 1: Plug-in, "OctanePlugin" was compiled against too old a version of the Maya API and is thus incompatible with the current Maya version.
MAYA: Autodesk Maya 2015 Extension 1 + SP5
OS: CentOS
matrix2012
Hi
Octane Render for Maya 2015 SP5 does not work this is the error message.
What Octane Render for Maya 2014 is here also a version :?: :(
OS:Centos
NVIDIA 680GTX 4GB
This version is definitely compiled against 2015 Ext1 SP5. :? I especially requested this version from our central branch and extracted the SDK from it.
So, the issue may be somewhere else... I will investigate it at Monday.
The plugin is compiled on CentOS 6.
matrix2012
Hi
The system we have is Centos 7 since Centos 6.5 had no support for GLIBC_2.14 error.
That's why we switched to Centos 7.
I would find it good if you also under Linux Octane Render for Maya 2014 - 20.. would support and not only Windows systems. :(
JohnMesh
matrix2012 wrote:I would find it good if you also under Linux Octane Render for Maya 2014 - 20
You could always check this thread
http://render.otoy.com/forum/viewtopic.php?f=28&t=42971
but in someway i would agree that it would be good to have support for maya 2014-201x in the *.run file. Im not sure how your environment setup looks like but if you have the SDK builds of maya 2014-201x installed this should be trivial to recompile for different maya versions, but i might be wrong.
Many linux folks are using 2014 aside 2015 due to changes in the API and viewport 2.0 issues.
We are running CentOS 6.5 here by the way. If i could help somehow let me know.
Try to re-download the installer file from the header of the thread, and install the plugin again. Should be OK now.
matrix2012
Hi
The Octane Render for Maya 2015 SP5 plugin is now loaded.
But man can not register
These are the warnings coming:
// Waring: line 1: Loading plug-in "OctanePlugin" has resulted in changes to the scene that may need to be saved. //
// Error: Error getting OctaneLive password //
// Error: Error activate Octane plugin: password attribute is not set! //
You are not first having this trouble. It is why I added these "sanity checks" to eliminate the Maya's user interface bug which I mentioned earlier:
JimStar wrote:Maya has stupid UI which does not switch the focus from the input field if you press the UI button when this field is active. You must explicitly get out from the field by "Tab" or by "Enter" to lose its focus. And before the field loses focus - it does not change the attribute which is bound to it... Stupid, but I can't change it - it's how Maya's UI works...:(
So, in your case - you had the ID attribute set, but the password attribute not set when pressed the "Activate" button.
So, now if the login or password attribute is empty - you will see this error. Just set the both attributes properly before pressing "Activate" button.
JohnMesh
Hi Jim,
thanks for the update. Seems to load and register fine so far.
I personally have the follwoing issue where i post a screen to help out.
Do you see the render settings and the Cuda Devices Tab?
Im not able to see and/or choose anything here.
I can open and close the arrow -> GPU Config menu inside Cuda Devices but that does nothing for me.
Im afraid our NVIDIA K6000 is not recognized correctly.
Return to “Autodesk Maya”
