Wine
Populus
Wine bottle and glass looks amazing! The reflection of the grapes could be driven by a texture map to make it a little more irregular.
win 7 x64 / i7 920 / 12GB / gtx 470 + gtx 480
truerender
Very high quality picture remon_v!
I like it!
The problem to which I am referring to the developers in the details.
On your picture it is subtle, not dramatic.
Looking closely at my publication, you will understand what I mean.
http://render.otoy.com/forum/viewtopic.php?f=27&t=25905
remon_v
Oke I made some tweaks to the scene.
Going to make a X-mas card out of it :D
I think I've solved the problem truerender is talking about.
When I made those wineglasses I modelled the wine a little smaller to avoid overlapping faces.
In this render I made the wine intersect with the glass.
I also added 3 lights to the scene but not sure if I'll keep them or not.
I upped the max depth from 16 to 32, but only left it render for 4 hours (with 460m GPU) so there's a little bit of noise.
Please feel free to leave a comment or a suggestion.
Win7 Pro x64, Phenon II 940, 8 GB, Geforce 470 - Modo, Zbrush
Tugpsx
Awesome! Much improved. Regarding the foil. It appears to be embedded in the bottle. i don't get the feeling that it is wrapped around it. But non-the-less this is exquisite work.
remon_v
Thanks! in the previous images the foil had no thickness at all. This time I extruded it a tiny but out to give it a thickness.
I also applied a bump map to it.
In the last image I like the lighting better on the foil, which made it pop more.
Any tips on how to fix this?
much better, as already said if you work on the grape it' perfect ;)
pay attention, the Chardonnay is white wine from white grapes ;)
Edit:damn, i've not seen the second page :oops:
sorry, forget what i've wrote :lol:
Return to “Works In Progress”
