Wine
remon_v
Hey guys,
Just a quick scene, to practise my materials.
All the materials are very simple setup. only the leave has mix material to get SSS working.
Comments and suggestions are welcome.
Win7 Pro x64, Phenon II 940, 8 GB, Geforce 470 - Modo, Zbrush
MaTtY631990
good setup and nice render :). Not sure about the pinkish color for the cap on the wine bottle, maybe stick with dark brown or black, not to distracting with color.
You might want to have a label on the bottle with make, type of wine ... etc. Also play a bit with vignetting on your image and see whether it improves it a bit more.
Refracty
good materials,
render time / samples ?
truerender
As we can see, in a glass of wine the wrong index. Octane is not correct to consider the situation. When an object is one (only glass) all correctly.
Mates prelomlyayuschh objects when one object inside another - with an error.
remon_v
Thanks for the comments guys.
I'm going to make a label for it... just have to search for a nice one :D.
I started the render just before I went to bed and it wasn't clean yet so I left it render over night untill it reaches the max samples (16000).
I don't really understand your comment 'truerender,' are you talking about the black border in the whine bottle and the hight light?
I think I see the problem, but I'm not 100% sure. How can I fix this?
remon_v
Oke I worked on it a little more.. still have to improve some small thing.
Comments and nice idea's to impove the scene are very welcome.
I maxed out the samples to 16000 and took between 5 and 6 hours.
Mode PMC.
Truerender, there is now wine in the bottle (yet).
Tugpsx
Very nice. Add texture to the grapes and foil and your'e all good.
MaTtY631990
Impressive :)
remon_v
Thanks guys.
Will add some textures to the grapes and foil.
Return to “Works In Progress”
