OctaneRender® for 3ds max® v1.0 beta 3.00[Test]
As far as I understood the series 5XX is still best for Octane because the 6XX isn't optimized. At the moment the GPU industry around Nvidia is a bit strange.
PURE3D Visualisierungen
Hi super_Karba
Thanks alot : i'll be able to render big scenes with only a 1.5Gb card
feels like christmas
can't wait to try it out
OK now what is the best way to set up grass, sharing some scenes would be quite beneficial now, give us a test scene
Here's a bug from before, if you already have octane assigned as the render, and choose a render preset that has an octane preset - every preset in render window is shown twice.. I had the render settings opened at the time - this happened on the previous version as well.. - it fixes itself if you close and open the render settings again
3dmax, zbrush, UE
//Behance profile //BOONAR
Unfortunatelly I don't have any good sample sceen with grass. I will prepare some thing.acc24ex wrote:feels like christmas
Usefull material for windows glass based on glossy material and falloff textrue.
It allow to pass light even with diret light kernel or sun light.
- thinGlass.zip
- (21.37 KiB) Downloaded 251 times
- gabrielefx
Thank you Karba for your work.
I would like to switch between 2.8 and 3.0 without uninstall both.
Is it possible?
Is it possible?
- Elvissuperstar007
- Contact:
я не интегрировн пока-что. но есть один неприятный момент! полезная функция конвертер материалов. он видимо работает только для интеграциии! пару раз пытался сконвертировать. все нормально . но стоило зайти в мат эдитор ..3д мах просто вылетал! мне хотелось посмотреть настройки шейдеров вирей в октан ! для пополнения онлайн библиотеки. интеграцию прикуплю в скоре , хотя в максе работать не охота
