OctaneRender® for 3ds max® v1.0 beta 3.00[Test]
mbetke
As far as I understood the series 5XX is still best for Octane because the 6XX isn't optimized. At the moment the GPU industry around Nvidia is a bit strange.
PURE3D Visualisierungen
bicket
Hi super_Karba
Thanks alot : i'll be able to render big scenes with only a 1.5Gb card ;)
PortFolio
4 x TITAN - Win 7 64 - Octane Rocks
Karba
jan kudelasek wrote: It look like that collorcorection have a problem. dont display any changes in mtl editor and oc viewport.
Fixed, wait for a new release.
Karba
jan kudelasek wrote: which tool did you use for the scattering the grass? Multiscatter?
I used multiscatter.
It is not supported directly.
I had to generate more than 40k objects in my scene and have extremely slow viewport.
acc24ex
feels like christmas :)
can't wait to try it out
OK now what is the best way to set up grass, sharing some scenes would be quite beneficial now, give us a test scene
Here's a bug from before, if you already have octane assigned as the render, and choose a render preset that has an octane preset - every preset in render window is shown twice.. I had the render settings opened at the time - this happened on the previous version as well.. - it fixes itself if you close and open the render settings again
Karba
acc24ex wrote:feels like christmas :)
Unfortunatelly I don't have any good sample sceen with grass. I will prepare some thing.
Karba
Usefull material for windows glass based on glossy material and falloff textrue.
It allow to pass light even with diret light kernel or sun light.
thinGlass.zip
(21.37 KiB) Downloaded 230 times
gabrielefx
Thank you Karba for your work.
I would like to switch between 2.8 and 3.0 without uninstall both.
Is it possible?
Elvissuperstar007
я не интегрировн пока-что. но есть один неприятный момент! полезная функция конвертер материалов. он видимо работает только для интеграциии! пару раз пытался сконвертировать. все нормально . но стоило зайти в мат эдитор ..3д мах просто вылетал! мне хотелось посмотреть настройки шейдеров вирей в октан ! для пополнения онлайн библиотеки. интеграцию прикуплю в скоре , хотя в максе работать не охота
Karba
gabrielefx wrote:Thank you Karba for your work.
Is it possible?
You can install another 3dsmax. If you have 64x, you can install 32x
Return to “Autodesk 3Ds Max”
