SSS Max problem + texture info
petermax
the max plugin is working well, no complaints... I just have one BIG problem SSS
1) SSS issue
through trial and error I finally got SSS to work in the standalone version, quite well actually, but I can NOT with the max plugin, changing the transmission and medium settings/ colors has no effect at all!
the issue I had with standalone was the incorrect scaling/ units, I had to set it to meters and scaling then it started working, so it's really important to get the scaling right apparently
but now with max, if I have units set to meters and scale a human character realistically at around 2m height for example, SSS has NO effect at all... how do I ensure the scaling is correct??
2) textures info
thanks for adding the info just what I needed, but could you tell me what the limit is for each item 0 / 0 / 0 / 0 <-- for a gtx 580 for example? is it 64/64/32/32 ??
thanks
Win 7 64 | 3 x GTX 580 | i7 950 | 24GB
Karba
petermax wrote:the max plugin is working well, no complaints... I just have one BIG problem SSS
1) SSS issue
2) textures info
thanks
1) What material do you use (Diffuse/Specular)?
2) I don't have right information about this. You can make a test to find a limit.
petermax
re SSS I use the following, with the right scaling it works really well in standalone, but does nothing in Max:
output is mix material, which consists of a diffuse + glossy material, the diffuse uses transmission containing a red color, the glossy contains a medium also containing a red color, those should give the skin a reddish SSS effect, but there's no SSS effect at all, let me know if you need a screenshot
petermax
is this a problem with the plugin... what should my scaling be?? thanks.
Karba
petermax wrote:is this a problem with the plugin... what should my scaling be?? thanks.
I have made an example.
SSS box in the scene should have 1m x 1m x 1m size for correct result.
DiffuseSSS.zip
(16.89 KiB) Downloaded 203 times
petermax
thanks, will try this out
nildoe
Karba thx for that simple scene..but i need to know 1 thing, is it possible to feel the SSS effect using Direct light and AO? if so would u mind sharing the same simple scene with DL and AO? im trying out this scene as it is and it only works with either DL, DIFF or just PT.
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
Return to “Autodesk 3Ds Max”
