Sketchup exporter not working on this file?
Fritsch
Can anyone tell me why this file crashes when I export a still image or animation of it to Octane 2.57, i'm using the latest TIG exporter 1024-09 but i'm always getting this message; node "summersolstice.obj" is no mesh
Yes I already tried the Sketchup fix problems and purge commands as well as all the option on TIG's Fix reverse faces plugin. There are nospecial charaters in the file path either. I know the program works because I can export other models but not this one.
Thank you in advance, cause I'm sure you Guru's know what's wrong.
summerSolstice.zip
(6.16 MiB) Downloaded 319 times
Patrick, Arch. Tech.
Fritsch Plans Workshop Inc.
http://www.FPWI.ca
SketchUp Pro 8, Win 7 Pro 64 Bit, i7 3.40Ghz, nVidia EVGA GTX 570 1280mb, 16384 mb RAM, Asus P8PP67
Jaberwocky
Can't explain why but exploding your various groups managed to solve this problem.
Octane exporter does not now crash.Something in one of your sets of grouping was causing the crash.It happened to me as well ,when i tried it initally.
I'd just use the attachment to do you render with as it's probably buggered up (a technical term used by us octaneers :lol: ) your grouping arrangements along with your hidden layers.
You may have to isolate, ungroup and regroup your various objects in your original model to isolate the offending object.
Jabba
Jaberwocky
sorry, forgot the file
please see attached
Jabba
summerSolstice-explode_groups.zip
(6.13 MiB) Downloaded 282 times
Fritsch
Hi and Thanks, I managed to find the problem Group entity, it was the 2 small roof knee braces that support the small roof located at the garage side man door. The roof was a Group that contained 2 the knee braces which were sub-group as well.
Do you thing TIG the developer should be advised there is an issue with multiple groups containing sub-groups? I would not know how to do that.
http://www.FPWI.ca
Jaberwocky
I'm not sure if the crash was instigated by the exporter or was a bug in Sketchup , or just a clash between the two.
Fritsch
I need to correct what I said before, I can render a still frame but i'm still unable to render the solar animation, start scene is "summer solstice start", and the end scene is "summer soltice end"?
Were you able to do this?
http://www.FPWI.ca
TIG
Your SKP worked fine for me - with no fixing.
I 'Purged' the SKP... but 'Fix Problems' did nothing to the SKP anyway.
Then it exported fine as both a render and an animation [of 2 frames !]
Octane 1.2.52b and Exporter v1024-09
TIG
Return to “SketchUp”
