a gtx 580 with 3g is always 3gb; only the dual-gpu 590 sold as "3gb" is in fact 2*1.5gb...tyrot wrote:i just wanted to ask - GTX 580's 3 GB ram is divided by 2* 1.5 gb ? or is it solid 3 GB for adding everything within that 3GB?
So trying to learn, is my memory limit 1.5 gb ram or 3gb ram?
Best
GPU advice
„The obvious is that which is never seen until someone expresses it simply ‟
A 580 is just a single processor. It uses the whole 3GB. It is only the 590 which is effectively 2 x 580s which split the memory.
(OS) Windows 7(64)
(OS) Windows 7(64)
3x gtx 590?steveps3 wrote:Just ran the standard benchmark scene and got 21.09Ms/Sec. Pretty good I think.
- mib2berlin
steveps3, the standard bench is set to direct light iirc, you have to change to pathtracing to get real results.
Cheers, mib.
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
Surely the "standard" should be as it comes out of the box. When I change to pathtracing I get about 4.5Ms/sec.
(OS) Windows 7(64)
(OS) Windows 7(64)
to be honest: this is a little slow for 3 4/560 carssteveps3 wrote:Surely the "standard" should be as it comes out of the box. When I change to pathtracing I get about 4.5Ms/sec.
imo.
i'd say you should see something between 5.5 and 6ms/sec - depending on the clocks of your cards...
then everything is just oksteveps3 wrote:With all three cards I get 6.03Ms/Sec. The other score was with just the 2 560s running.
