OctaneRender® for 3ds max® v1.0 beta 2.56 [OBSOLETED]
jamestmather
merid888 wrote:hi karba, i have a question, when do you think repair the bug of pathtracing in octane for 3ds max ? becouse i have a few image to do into octane but the noise is a big problem, thank you for read this post
Make all your scene materials glossy - the ones you don't want shiny knock down the specular and up the roughness. This seems to get rid of the fireflies - the only diffuse mats in the scene should be blackbody emitters - I am getting acceptable results and times this way with Octane. Also, for extra speed and cleanup , stay on directlight but go down to the direct light tab and change GI-mode to diffuse (this gives better much GI (looks very like pathtracing actually) but cleans up much quicker in max.
Hope that helps.
James
gabrielefx
Hope that helps.
James
BTW...
the update was to be released yesterday...if I remember well
KaroBastardKiter
any plans to export the renders into an .ocs to use in the standalone version?
Alienware M17x R3 | GTX 460M | Quad 2.0 GHz | 8 GB
Win 7 x64 | Blender 2.59 | Octane
wxyz
Max to Octane still works
KaroBastardKiter
Another small bug I have noticed:
When using Octane standalone after using Octane for max, standalone can't remember 'Recent Files'... but most important forgets the Settings!!! :ugeek:
t_3
time to remind about an old bug (at least since 2.52): if pathnames contain blanks or special characters, octane won't find image maps while loading an .ocs/.ocm (windows)...
„The obvious is that which is never seen until someone expresses it simply ‟
User avatar (Default)
merid888
hi, thanks all for response me, gabrielefx, where is the update and wich version ? standalone or octane for max ?
why i need change my units meter for milimeters ? the reason is ?
i need see the textures in the slot, like standar material or vraymaterials or scanline materials
thank you
is directlight with 1000 maxsamples, size i don't know becouse i put 2600 x 1500 and the screen was black, i don't know why happen this, so i strech the image resizing the view without a number
thank you for the tip jamestmather, i add image witg diffuse
second image using GI_mode diffuse
exterior look so false
Return to “Autodesk 3Ds Max”
