OctaneRender® 1.025 b2.55b test release [obsolete]
PeterCGS
Uhm, I thought normalize was for if you had different emitter sizes, and wanted them to be less/more intense based on size, not Kelvin?! Ok, cool I will test this...
Win7, i7 980 Hexacore, 24GB RAM, 3xEVGA SC 670 GTX 4GB
Elvissuperstar007
when the color changes in the adsorption, it makes a totally different color!
Proff54
Problem.
In my scene animated UVW. On what staff the texture gives failure. The texture lays truly, but on it there are not clear distortions.
Has lead the test same scene in previous version Octane 2.52. The similar problem does not arise. Apparently the problem is connected with transition to a new method of concept of geometry inside GPU.
Respectfully, Anton.
I am sorry for bad English.
no problem 2.52
no problem 2.52
texture problem 2.55 beta
I7 3930K 6 Core+HT 3,3 Ghz / 64 GB Ram / GTX690 for Octane / Quadro4000 for display / Win 7 64 Bit
gabrielefx
waiting for the 2.6 for Max
In Max we have immediate feedback...and if it works in Max should work on Octane core too.
Regards.
Proupin
Elvissuperstar007 wrote:when the color changes in the adsorption, it makes a totally different color!
afaik, you have to choose the color you want absorbed, so the opposite color is what comes out of the material. If the material absorbs green, it will look red.
Win 7 64bits / Intel i5 750 @ 2.67Ghz / Geforce GTX 470 / 8GB Ram / 3DS Max 2012 64bits
http://proupinworks.blogspot.com/
roeland
Proff54 wrote:Problem.
Yes, this is probably due to our new geometry storage in the engine. What kind of scene is this, and what is the shape of the object?
Roeland
Proff54
I can simplify the project and send you, it will be not complex (c4d + ocs).
matej
Minor glitch, the colors in the gradient bar do not correspond (different gamma?)
I also don't like how Octane color picker works. Because it's not gamma corrected, you cant copypaste color values from other applications, but because the palette is so washed out is also hard to pick dark & saturated colors inside Octane. Look at the picture below; the regions for saturated colors is so tiny (top 10% - 15%) opposed to the region of desaturated colors. The bottom 20% is all pure white. The same way is hard to set a dark black, since white spans over 60% of the picker bar and really dark black begins at the lowest 10% - 5%. Clicking two pixels off, makes a visible color difference in the render.
It would be good to have the option of a linear or gamma corrected picker.
cgmo.net
ROUBAL
I completely agree with matej about the color picker. I hate the way it displays !
iViz3D
How about adding color dropper/ picker tool?
