btw does anyone know where the recent files list is kept? I want to clear it. this really bugs me.
OctaneRender® 1.025 beta 2.51 [OBSOLETE]
i7-3820 @4.3Ghz | 24gb | Win7pro-64
GTS 250 display + 2 x GTX 780 cuda| driver 331.65
Octane v1.55
Octane v1.55
Yeah, sorry, no time yet. It's noted though - we will not forget itpixelrush wrote:still no animation .png/exr... I guess you get to it eventually
On Windows it's in your user folder under ...\AppData\Roaming\Refractive Software.btw does anyone know where the recent files list is kept? I want to clear it. this really bugs me.
Cheers,
Marcus
small UI issue to report - probably there before just hadnt noticed:
grab left edge of render window and drag horizontally to resize and everything is cool - but if grab and drag right side the left side moves horizontally as well although much less. >--->> or <---<<
drag right edge completely to the left and back and left edge follows at what looks like the half distance
edit: worked out viewport lock at last
I wonder if it would be better to call it 'viewport/resolution coupling' rather than lock.
I was thinking of a lock of zoom or rotation or something as in frozen which it isnt...maybe I'm thick though
Tooltip explanation: 'When enabled changes in the viewport aspect are coupled to change the resolution'
Octane v1.55
Octane v1.55
- Jaberwocky
Ok did some speed test comparisons on one of my old scenes.
2.49b
Direct lighting A.O mode
Using HDR lighting 11.47 s/px
daylight 10.74 s/px
Pathtracing
Using HDR lighting 1.95 s/px
daylight 1.36 s/px
2.51
Direct lighting A.O. mode
Using HDR lighting 11.39 s/px
daylight 10.89 s/px
Pathtracing
using HDR lighting 1.94 s/px
daylight 1.35 s/px
as you can see the current version , speed wise is virtually the same as 2.49b
I was not able to test with an earlier version of octane as they bomb out using the latest Nvidia drivers that I am running and i didn't want to uninstall those!
2.49b
daylight 10.74 s/px
Pathtracing
daylight 1.36 s/px
2.51
daylight 10.89 s/px
Pathtracing
daylight 1.35 s/px
I have some heavy performance problems on Linux (Kubuntu 11.04, driver version 280.13), the view updates are VERY slow, sometimes I can't even pause a render and it's impossible to do anything else while rendering, because there is a view update just every second or so. Later in the rendering process (after several dozen or hundreds of samples) it's even worse, I just had 5 minutes to kill octane, as the system didn't respond really on any clicks anymore. The whole screen was more or less frozen, the only thing possible was moving the cursor.
The problem already appeared in 2.49b and 2.50 (don't remember all builds before, but it worked once perfectly for sure)
Kubuntu | Geforce GTX480 | AMD 6x3.2GHz | 12GB
with 2.48 - 2.5x i had the same problems as felix. especially with huge scenes (about 2gb vram usage).
if i remember right navigation was much better under 2.46. atm i have no time/hardware for specific testings., maybe next days i find some more details and could post some test scene.
@marcus: could you use a blend file? (obj/ocs will bee to big)
hardware/os: see sig amdX6 sys +mint10
- Mint 10 64bit nvidia drv 260.19.29/cudatoolkit3.0 intel q6600, 4gbRAM, GTX470 1,2GB
- Mint 10 64bit/ Win7 64bit nvidia drv 260.19.29/cudatoolkit3.2 amd X6, 16gbRAM, 2x GTX580 3GB
->Octane 2.44/ Blender2.5x
I notice that the tool tip problem with the 2x2 and 4x4 sub sampling icons have not been solved yet.
(OS) Windows 7(64)
(OS) Windows 7(64)
Thanks for the betas Octane team. I'd like to share some issues I'm running into.
1. In Linux, when I launch octane, all of the settings from the right panel are moved (mismatched) 1 place; i.e. in the screenshot I'm mousing over camera options and it displays "current resolution" options, If I click on current resolution options it will display the environment options and so on:
Only after maximizing/minimizing the interface do they go back to their respective positions.
2. In Linux, I load an obj file, but scene's tris/gpu count displays 0 so all I get is an empty/gray scene.
3. In windows, the obj file loads fine, but after tweaking the scene options a bit the render freezes. All the rest of the interface seems to be alive, but I can no longer orbit, rotate, pan or zoom my model in the viewer.
Gonna run some more tests to see what else I run into.
cheers,
Alvaro
cheers,
Alvaro
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
