Please try again from the following link and report back, thanks:
https://render.otoy.com/customerdownloads/plugins/0e/ac/2a/ff/OctaneRender_Studio%2B_2026_4_for_Cinema4D_v1.9.5_Bundle.zip
ciao,
Beppe
Octane 2026.4 for Cinema4D - v1.9.5
Thanks for the response. I do ArchViz on top of 3d tracked drone footage. The video files/footage is 4K 60fps and can sometimes be up to a minute or more. so having to convert all that footage to image sequences takes quite a bit of times, sometimes up to an hour and a ton of disk space. Being able to use video files would have been super convenient but I guess it ain't happening.bepeg4d wrote: Wed Sep 02, 2026 8:14 am Please note that you need only few clicks to convert any video into an image sequence via C4D Picture Viewer.
And yes, Standalone doesn't accept video assets, so it doesn't make any sense to develop a feature only from c4d plugin side, that doesn't work in OctaneRender ecosystem.
If you want to ask for new core features, please use the following forum discussion:
viewtopic.php?t=37045&start=550
ciao,
Beppe
Thanks again! Have a nice day!
Ok, if converting to image sequence is not a valid option, better to render with alpha channel and compose in AE.
ciao,
Beppe
ciao,
Beppe
This is working for me, thank you Beppe!bepeg4d wrote: Thu Sep 03, 2026 9:10 am Please try again from the following link and report back, thanks:
ciao,
Beppe
That's indeed what I do. It's just that being able to see a preview of how things line up and how the lighting looks on top of the drone footage in the live viewer is super helpful and convenient. I'll continue using low quality JPEG sequences for now. They take time to encode but that's I guess my only option. Appreciate the help. Thank you.bepeg4d wrote: Thu Sep 03, 2026 10:09 am Ok, if converting to image sequence is not a valid option, better to render with alpha channel and compose in AE.
ciao,
Beppe
- lukesky345
Is there any word on weather or not any of these last updates fixed an issue to rtx 2000s cards specifcally that out of core was not working properly.
Hey all! Last week, there was a new xParticles / Insydium public beta released - unfortunately the new nxEmitter doesn't seem to be recognized by the Octane Object Tag, so particles can't easily be rendered as geometry like before.
The same issue applies to the Instance Color and Instance Range nodes that expect an emitter but can't read the new one.
Is there anything here that could be done from the Octane side or would Insydium need to update the new emitter to make it work with Octane?
It's still in beta and it makes sense that interactions between two independent plugins need time to be worked out. Still, being able to test it while already using Octane would of course be much more enjoyable than viewport renders. : )
