Octane 2026.4 for Cinema4D - v1.9.5
ChrisHekman
Hi all,
This build contains OctaneRender 2026.4 and a couple of bugfixes.
We are aiming to release a 2.0.0 next with new features and the upcomming OctaneRender 2027 Beta soon-ish
To see what the future holds, check out our Trello!
https://trello.com/b/1HYU24R0/octanec4d
2026.4 - 1.9.5 plugin revisions
  • Added option in octane object tag to define the hair width using a curve
  • Fixed pyro placement transform issue
  • Refactored Export and Save-image dialogs
  • Matlink Crash Fix
  • Fixed reset issue with camera and imager tags
  • Fixed issue with subdiv parameters for instances
  • Switching scatternode on a material no longer deletes downstream nodes
  • Image file paths that don't exist are no longer send to octane
  • Added Octane plugin build info to C4D Scene Setting
  • Added missing UV coordinate selection pin for UV coordiante AOV
  • Avoid disabling solo as long as material is in nodegraph
  • Fixed film width setting in sub material
  • Fixed alembic particle issue
  • Cancel image sequence now works correctly on export dialog
  • Octane Settings panel no longer pops out of docked layout
  • Fixed Octane windows with monitor DPI on Windows
  • Added insert button for dynamic pins
  • Added JPG compression option
  • Fixed issue where material nodes started all the way on the left of the nodegraph editor
Downloads:
WINDOWS STUDIO+ 2026.4 - 1.9.5 (R21-R2026)
Installer
Archive
Installer Chinese
Archive Chinese
MacOS Prime 2026.4 - 1.9.5 (R21-R2026)
Archive
WINDOWS DEMO 2026.4- 1.9.5 (R21-R2026)
Installer
Archive
2026.4 - Nodes
OctaneRender Studio+ 2026.4 Node for Windows (installer)
OctaneRender Studio+ 2026.4 Node for Windows (ZIP archive)
OctaneRender Studio+ 2026.4 Node for Linux
Support
Some important notes about these builds:
The minimum NVIDIA driver version required is R535 (R572 for GeForce RTX50 series).
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.5.1, R2025.3.3, R2026.1.2). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 528) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRenderforCinema4D.html
Archive Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
martinzip
Dear Chris and Beppe
yesterday apple announced the new M5Ultra... and also Apple AI server with M5Ultra Racks seems to come in the near future...
We need urgently the mac render nodes back! I asked already in the dev Team but there is nobody answering since months...
Please put some gentle pressure on the devs, apple is so f...ing stable with octane at the moment... and the big amount of unified ram ...
Now we need them urgently! Imaging apple AI Server is out and we cannot render octane on them, what a pity !
Waiting for some good news...
Martin
Tim0042
Hm, creating a Fog Volume (via the button) in an empty scene and then rendering brings up a message in the log: "The size of the volume array attributes does not match. They will be ignored."
This is not a message I remember from working with volumes in the past, though I could be wrong. What is Octane telling me / warning me about here?
It's just a standard Volume object, unchanged from how the plugin sets it up. It is not reading an external file, so there's no velocity, temperature, etc. What is the mismatch between?
hoffwerr
Any chance we can get animated textures working if they're video files?
It works fine on both geometry and background objects if they're image sequences.
Video files are a different story. On geometry, it shows up on the live viewer but it doesn't refresh unless I refresh the scene. On background objects it just flat out doesn't work at all.
@Tim0042:
We have changed the way log works.
The specific message is a warning, nothing serious, but I'm with you that shouldn't be there, thanks for the report!
@hoffwerr:
This is a request for Standalone Core team, we cannot introduce a feature like this from plugin side only.
ciao,
Beppe
Tim0042
bepeg4d wrote: Tue Sep 01, 2026 8:15 am @Tim0042:
Aah, ok! Thx, that is very good to know - trying to optimize a scene and I wasn't sure if I need to worry about that message. But then I'll just ignore it for now! : )
Something else that came up while looking at optimization: The currently defined max for Out of Core textures/geo seems to not show up as such in the LV, as it just says "0 B" out of a maximum of "0 B".
On further testing, I cannot get it to show any OOC used at all, even when one is definitely being used. Tested it by disabling one GPU and adding geo to the scene - textures no longer all fit, but the scene still renders. OOC used/max still says "0 B/ 0B".
Once I disable OOC, predicted render time jumps up a ton so it seems like the feature itself still works as expected, but the LV reporting is off?
hoffwerr
@hoffwerr:
ciao,
Beppe
Is it? Sorry I'm just making sure I relayed this correctly. It's a standard c4d material with a video file in the color channel applied to a background object. I
t works fine in the viewport and when it's rendered using standard or redshift. It's just octane that seems to hang up when there's video files used. Is that still considered an Octane core issue/feature ? If so, where can I report it ?
Please note that you need only few clicks to convert any video into an image sequence via C4D Picture Viewer.
And yes, Standalone doesn't accept video assets, so it doesn't make any sense to develop a feature only from c4d plugin side, that doesn't work in OctaneRender ecosystem.
If you want to ask for new core features, please use the following forum discussion:
viewtopic.php?t=37045&start=550
ciao,
Beppe
y81r
I don't know what's going on, but I can't activate Octane 2026.4 for Cinema4D - v1.9.5.
When I click the "Activation" button in settigs, nothing happens, and Octane remains in demo mode.
Octane 2026.4 for Cinema4D - v1.9.4 works fine.
y81r
The Archive Download has this problem; the installer .exe works fine for activation. I generally need the Archive Installer due to company regulations.
