Octane 2026.4 for Cinema4D - v1.9.4
ChrisHekman
Hi all,
This build contains OctaneRender 2026.4 and a couple of bugfixes.
We are aiming to release a 2.0.0 next with new features and the upcomming OctaneRender 2027 Beta soon-ish
To see what the future holds, check out our Trello!
https://trello.com/b/1HYU24R0/octanec4d
2026.4 - 1.9.4 plugin revisions
  • Octane 2026.4
  • Updated to render network wizard 1.07
  • Vectron rotation fix
  • Logging performance fix
  • Fixed some MacOS crashes related to licensing
  • Fixed issue with show passes and denoised PV export
  • Show render stats for Command line render
  • Added output type to Image Texture and OSL Texture nodes
  • Fixing text alignment in OOC settings
Downloads:
WINDOWS STUDIO+ 2026.4 - 1.9.4 (R21-R2026)
Installer
Archive
Installer Chinese
Archive Chinese
MacOS Prime 2026.4 - 1.9.4 (R21-R2026)
Archive
WINDOWS DEMO 2026.4- 1.9.4 (R21-R2026)
Installer
Archive
2026.4 - Nodes
OctaneRender Studio+ 2026.4 Node for Windows (installer)
OctaneRender Studio+ 2026.4 Node for Windows (ZIP archive)
OctaneRender Studio+ 2026.4 Node for Linux
Support
Some important notes about these builds:
The minimum NVIDIA driver version required is R535 (R572 for GeForce RTX50 series).
Open Image Denoise is supported on CUDA compute model 7 and later, we fallback to the CPU version on machine with older models.
IN ANY CRASH CASE PLEASE DO THESE!!!
If you see CUDA errors follow 1,2,3,4.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
2- Check GPU frequency. Overclocking would cause instability issues
3- Check PSU. Insufficient power output would cause instability issues
4- Check the free amount of GPU's VRAM and system's RAM while working. Low VRAM will/may cause CUDA errors. Be aware of some generator objects will have different triangle count in Picture Viewer than Live Viewer. It’s like “editor/render” parameter. Just try to use the same value. Also try to optimize your scene for polygon count, even use smaller images. Try to use Octane texture nodes rather than using C4D texture/shaders.
Alternatively, use V4 and Out-of-core(OOC) function. Increase RAM for OOC and It should not exceed physical RAM amount. Check TDR value and increase if it's necessary.
5- If you see C4D crashes without CUDA errors, then send us bugreport.zip, screen-shots and video capture to show process and crash moment. Also please send us a sample scene in a format of C4D or ORBX to let us investigate and test it. Alternatively, try to delete/hide some objects/materials until crash gone away. If you find what's causing crashes, send us a sample scene to let us for investigating and bring a fix or solution.
Thanks for helping the development by your feedbacks! It’s impossible to quickly catch every case without user feedbacks! It’s the same procedure as other companies do like Maxon/etc...
Please note the macOS build will only work correctly on macOS 14.5 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2, R2024.5.1, R2025.3.3, R2026.1.2). Otherwise, the plugin will not work and not appear in menus.
-Internet connection for activation, be sure that C4D and Octane will not be blocked by the firewall and any antivirus software.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 528) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
Use embedded help buttons from Octane nodes and windows
or from link: https://docs.otoy.com/cinema4d/OctaneRenderforCinema4D.html
Archive Installation
First, remove all octane related stuff from plugins and the main folder of Cinema4D.
Also, download manual.zip and extract to c4dOctane directory if it's not available in place.
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
Kalua
Thanks, team!
Octane User since V1 Beta
eyeonestudio
Thank you for the update.
Could you please explain what this update actually means and how it should be applied?
Without any additional explanation, it is difficult to understand how to use this new feature.
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
DinoMuhic
eyeonestudio wrote: Mon Jul 20, 2026 5:01 pm Thank you for the update.
Very easy, if you for example want to use an imagetexture which has Alpha for color but also utilize its alpha channel at the same time, do this:
Just use an Extract4 (MX) node and set it to ID = 3 (0 = R, 1 = G, 2 = B, 3 = A)
eyeonestudio
DinoMuhic wrote: Mon Jul 20, 2026 9:18 pm
Thank You. In OSL, color4 is not recognized. How can I output the alpha channel from "color TEX = 0" in OSL?
ChrisHekman
eyeonestudio wrote: Tue Jul 21, 2026 9:23 am
#include "vector4.h"
shader OslTexture(vector4 vec4 = {},
output vector4 c = {})
c = vector4(0.7, 0.7, 0.7, 0.1) + vec4;
Here is an example OSL shader
Alternatively something like this:
#include "color4.h"
shader OslTexture(
color vec = 0,
output color4 c = {})
c = color4(color(0.7, 0.7, 0.7), 0.1) + color4(vec, 0);
Pins for vector4 and color4 need to be added on the plugin side, we already have a ticket for this.
eyeonestudio
ChrisHekman wrote: Wed Jul 22, 2026 12:21 pm
#include "color4.h"
shader OslTexture(
color vec = 0,
Thank You...... :D :)
y81r
Hi, for the past few versions, whenever changing settings like "Max Samples" or enable "Adaptive Sampling" in the Octane Settings,
the ACES tone mapping setting in the camera tag is reset, and the image is displayed in the Picture Viewer without ACES.
I prefer to work with settings per camera rather than global camera settings. It would be great if you could fix this. Or is this just on my end?
I also noticed that the Transform and Projection nodes are no longer in the node menu on the left side of the Node Editor, or i´m blinde.
I know I can find them using the Tap key, but out of muscle memory for years, I'm sometimes faster using the menu on the left side of the Node Editor than using the Tap function.
Thank you.
Kalua
What happened to "Export Animated ORBX package?"
Used to work well. Now it opens Picture Viewer and renders frame 1...
Gonna take long to fix that?
Tired of rolling back everytime something stops working.
PS.: So it actually does export an ORBX file, but only frame 1.
How to export all frames?
PS2.: So I rolled back to v0130, which is 2024 version, am getting same results. What have I messed up to get these results out of something that has always worked flawlessly to me?
ORBX-1.mp4
(2.94 MiB) Downloaded 57 times
Kalua
y81r wrote: Fri Aug 07, 2026 8:55 am Hi, for the past few versions, whenever changing settings like "Max Samples" or enable "Adaptive Sampling" in the Octane Settings,
Thank you.
Live viewer does behave oddly at times when I touch kernel settings.
Tone mapping loses its original configuration or something.
Reloading the scene in Live viewer window fixes it.
So no, you are not the only one facing this issue AFAIK.
Return to “Releases”
