In Corona Renderer, there's no detail when assigning the texture in "Show Shaded Material in Viewport."
I believe the issue lies in the OctaneRender algorithm.
I'm using Windows 11 Pro for Workstations x64.
No appear the texture in the object
- Pelana001_1
- Contact:
- paride4331
Hi Pelana001_1,
To be honest, it’s not entirely clear what’s causing this issue, and even the developers don’t have a solid explanation at the moment. Here are a few suggestions to try:
On Octane preference > Tools menu > "Refresh materials and textures in max viewport and material editor"
try the Invert of a RGB image, that should update / refresh both the image in the material editor, and in the 3ds viewport
In 3ds Max Viewports Configuration, there is Viewport Images and Textures Display Resolution: make sure the Maximum is not set to 1 or very low (default should be 1024)
Also, could you test my scene and check whether the issue occurs there as well?
- test02.zip
- (624.75 KiB) Downloaded 5 times
- Pelana001_1
- Contact:
Hi parid4331, well, it's the same result; the textures aren't visible on the objects when they're applied.
I think it's either 3ds Max 2026 version 3.2 or the Nvidia A4000 driver.
Until the 3ds Max 2027 version is released, I'll install it and see if it causes the same error or if it's fixed.
Thank you for your patience in trying to resolve this issue.
Windows 11 Pro for Workstations x64, Ryzen 5950x, 128 Gb ddr4 Bus 3600 mghz, Noctua NH-D15, M2 1 Tb SSD WD Black SN850X NVMe 7300 mbps, 8 SSD HP S650 1 TB, 1 RTX A4000, power source Corsair 850 w Platinum Series, mb X570 wifi plus Asus
- paride4331
Hi Pelana001_1,
Try resetting the Nitrous viewport: go to Customize > Preferences > Viewports > Choose Driver > switch from Nitrous DX11 to DX12 (or vice versa), then restart 3ds Max.
- Pelana001_1
- Contact:
Hello parid4331, thank you for response, but I been did this step of the restar Nitrous and nothing happen.
- paride4331
Hi Pelana001_1,
If possible, installing 3ds Max 2027 you can try setting up Octane for 3ds Max first, before installing any other render engines, to check whether the issue occurs.
- Pelana001_1
- Contact:
It's work for right now in 3ds max 2027.
Just making several tests to be sure.
Thank you fotr you patience with me paride4331.
