Hello OR team, I'm having an issue when applying textures to objects or surfaces.
The texture isn't displaying on the surfaces. The material is a simple diffuse/RGB image. When I click "Show Shaded Material in Viewport," I only see a color, as if the object isn't mapped, even though it is.
However, the texture appears correctly in the render, with its coordinates displayed correctly.
This only happens when I select the Diffuse/RGB image material.
Thank you if someone from the OR team could help me.
I've attached a test image.
No appear the texture in the object
- Pelana001_1
- Contact:
- paride4331
Hi Pelana001_1,
I can't reproduce your issue, I think it doesn't depends on Octane, please try this:
Viewport driver: in Customize > Preferences > Viewports, which driver are you using (Nitrous Direct3D 11, Direct3D 9, OpenGL)? Try switching it and restarting Max.
Material corruption: try recreating the material from scratch in the same scene. Sometimes a node gets corrupted and the issue only affects that specific material, not all of them.
Regards
Paride
Regards
Paride
- Pelana001_1
- Contact:
Hi paride4331, thanks for replying, I'll try to follow your instructions.
In Corona Renderer or V-Ray, this doesn't happen; all the textures applied to the different objects are visible.
Windows 11 Pro for Workstations x64, Ryzen 5950x, 128 Gb ddr4 Bus 3600 mghz, Noctua NH-D15, M2 1 Tb SSD WD Black SN850X NVMe 7300 mbps, 8 SSD HP S650 1 TB, 1 RTX A4000, power source Corsair 850 w Platinum Series, mb X570 wifi plus Asus
- paride4331
Hi Pelana001_1,
Could you share a scene where the issue occurs and tell me which plugin version you’re using?
Regards
Paride
Regards
Paride
- Pelana001_1
- Contact:
Sure, I can attach the file and send it to you.
An the version is OctaneRender 2026.2 - 26.5 to 3ds max 2026
- Attachments
- Interior.rar
- Interior.RAR
- (58.19 MiB) Downloaded 61 times
- paride4331
Hi Pelana001_1,
Everything seems to be working fine. Could you try uninstalling and reinstalling the plugin?
Regards
Paride
Regards
Paride
- Pelana001_1
- Contact:
Hello Paride4331, I¡ll do it right now and I let comment to you quickly
- Pelana001_1
- Contact:
Hi parid4331, I've reinstalled the plugin, and the result is the same.
I've attached a sample image.
- paride4331
Hi Pelana001_1,
Maybe you could check the settings like in the screenshot.
Regards
Paride
Regards
Paride
- Pelana001_1
- Contact:
Hi parid4331, that option is enabled by default.
The truth is, I don't know what else it could be.
I think it's either 3ds Max 2026 version 3.2 or the Nvidia graphics driver version 595.97.
Thanks in advance.
Thanks in advance.
