Octane 2025.5 for Unreal Engine 0.86
Moderator: ChrisHekman
ChrisHekman
Hi all
Here is a release with various fixes and improvements.
For the next patch the focus will be Unreal 5.7, Octane 2026 and supporting meshlets and virtual texturing
Octane for Unreal Engine
Changes:
  • Upgraded to Octane 2025.5
  • Material preview rendering is now asynch, so UI is no longer sluggish in the octane mateiral editor
  • Added a fallback node to the Octane to Unreal material converted for nodes that are not supported by the converter or unreal
  • Added various node conversions for the Octane to Unreal mateiral converter
  • Octane to Unreal mateiral converter now autoformats the created unreal material
  • Octane to Unreal mateiral converter now has fewer redundant and duplicate nodes
  • Fixed spline mesh issue where incorrect mesh was generated for octane
  • Moving nodes in Octane Material Editor is now correctly saved always
  • Fixed situation where the usage of vertex normal in materials could break in Octane
  • Fixed Unreal to Octane material conversion crash
  • Camera now works correctly when rendering out a sequence via the commandline
  • Fixed MRQ crash
  • RGB Image nodes now accept any type of texture instead of only texture2d
  • Animated textures now work in octane materials
  • Animated textures are now in the correct color space
  • R32 float and ARGRf32 support for textures
WIN
UE 5.6
Studio+ Installer: https://render.otoy.com/customerdownloads/plugins/26/e2/b8/bc/OctaneStudio0_86_UE5_6.exe
Free Version Installer: https://render.otoy.com/plugindownloads/2c/ba/95/f8/OctanePrime0_86_UE5_6.exe
UE 5.5
Studio+ Installer: https://render.otoy.com/customerdownloads/plugins/63/43/88/02/OctaneStudio0_86_UE5_5.exe
Free Version Installer:https://render.otoy.com/plugindownloads/af/11/72/48/OctanePrime0_86_UE5_5.exe
MakB
Hi Chris,
Thanks for the update. it stopped octane from crashing however metahuman materials dont convert and render grey. It was mentioned to use ray tracing kernel in 0.80. I have tried direct and path tracing so far.
I appreciate your help on this.
Return to “Releases”
