Global Color Correction Dial
coilbook
Can we please get a global color correction dial that allows us to make the whole scene black and white, while excluding certain objects from the correction? I know it can be done by object, but applying color correction individually to thousands of objects just to exclude one or two is impractical.
paride4331
Hi coilbook,
I gave it a try, it looks like it works by leveraging AOV groups. Take a look and see if what you need is feasible along these lines.
test_01.zip
(146.08 KiB) Downloaded 62 times
coilbook
paride4331 wrote: Tue Sep 16, 2025 1:07 pm Hi coilbook,
Hi Paride,
Could you upload 2023 version?
Also will it work with phoenix, itoo forest, etc.
Thank you!
paride4331
Hi coilbook,
It may seem that way, but I think it makes more sense to split between the objects that should be desaturated and those that shouldn’t.
test_02.zip
(193.82 KiB) Downloaded 62 times
neonZorglub
paride4331 wrote: Wed Sep 17, 2025 12:44 pm Hi coilbook,
Hi coilbook,
Using the same AOV idea as Paride, you can also select the objects using cryptomatte mask.
There should be a crypromatte 'type' that fits your needs.
Here is a sample using 'Object node name' :
aov04_globalCol_FP_cryptomatte_mx21.zip
(67.88 KiB) Downloaded 68 times
(make sure Preferences/Troubleshooting/Use max node names is enabled)
coilbook
neonZorglub wrote: Wed Sep 17, 2025 1:18 pm
Hi coilbook,
Can we still get a global dialog to make it easier? Thank you
Return to “Autodesk 3Ds Max”
