OctaneRender for DAZ Studio 2025.2.1 - 403 [OBSOLETE]
Moderator: BK
Hun73rdk_1
BK wrote: Thu Jul 10, 2025 10:41 pm
Hun73rdk_1 wrote: Thu Jul 10, 2025 3:17 am Linking DOF to Daz camera will brake Octane and Octane will not respond to moving the camera but will change the DOF instead
Hi Hun73rdk_1,
Thanks for the post.
Could you please share the steps to replicate this issue?
We are unable to reproduce it.
Cheers
Put in a model and a camera set up dof on the cam open render viewport and link to daz cam in dof and and set do not switch cam in thee viewport and try and move the camera with the scroll. Viewport will not move cam but move the Dof instead
Join the Octane Daz Fan server for people that uses daz and octane https://discord.gg/wDzwC8tqAK
BK
Hun73rdk_1 wrote: Fri Jul 11, 2025 1:35 am
Hi Hun73rdk_1,
Cheers
Hi Hun73rdk_1,
Thank you for the steps.
Interestingly, the Link to Daz camera works on our side. It seems to break if we use the Auto focus and the Set camera focus on the selected object tool from the OctaneRender Viewport.
We have a ticket to investigate this issue.
Cheers
Kind Regards
bk3d
Sorel
I have another bug that has existed since the last version as well and is pretty consistent. Open daz, load a scene, use a template preset on any surface. Close scene, open scene try to use a template preset again and studio will crash.
SiliconAya
BK wrote: Wed Jul 02, 2025 8:45 pm
SiliconAya wrote: Fri Jun 27, 2025 6:07 am First off, thanks for the update!
I just got this crash while using this new version of the plugin and while access violation crashes are rather common in Daz Studio, this is the first I've had that lists octane.dll in a long time (years?), as there was a concerted effort to report and fix them all a while back.
At the time I was panning the camera, which doesn't really seem related to the crash, so not sure that helps.
Is there anything else that should be provided next time i get a crash or is this enough?
Hi SiliconAya ,
Thank you so much for reporting this.
We are unable to replicate the crash on our side.
Would you happen to remember the steps and was there any AOV enabled from the interactive viewport.
Cheers
I just got this crash again, exact same exception error message, (I think I've had it a few times now), the crash just seems to happen, it's not consistent with any one activity, this time rather than panning the camera, I was adjusting the pose (bone) of G8Fs leg.
I don't believe any AOVs where enabled, it's happened in a number of both new and old scenes and I haven't touched AOVs in any of them.
BK
Sorel wrote: Fri Jul 18, 2025 4:40 pm I have another bug that has existed since the last version as well and is pretty consistent. Open daz, load a scene, use a template preset on any surface. Close scene, open scene try to use a template preset again and studio will crash.
Hi Sorel,
Thank you for the post.
Which version of genesis are you using?
We are unable to replicate with Genesis 9 "Lesya.duf" and the "Barefoot Dancer" character.
Do you happen to have the `Automatic material updates after the content loads` in the Preferences folder?
cheers
Kind Regards
bk3d
Sorel
BK wrote: Mon Jul 21, 2025 2:08 am
Hi Sorel,
cheers
Hey BK, the crash happens with literally anything. I've also tried with `Automatic material updates after the content loads` on and off. This is the crash file I get from daz when it happens.
DAZStudio_error_report_250722-125447.zip
(147.3 KiB) Downloaded 111 times
BK
SiliconAya wrote: Sun Jul 20, 2025 4:05 am
Hi SiliconAya ,
Cheers
Hi SiliconAya ,
Thanks for the post. We are still unable to replicate the crash with G8Fs and G8.1Fs character..
Does Daz show any popup after the crash? Please send us the logs
cheers
Kind Regards
bk3d
BK
Sorel wrote: Tue Jul 22, 2025 6:02 pm
Hi Sorel,
cheers
Hey BK, the crash happens with literally anything. I've also tried with `Automatic material updates after the content loads` on and off. This is the crash file I get from daz when it happens. DAZStudio_error_report_250722-125447.zip
Hi Sorel,
Thank you for the logs.
Would you please send a screenshot of the Preferences? Maybe can DM me.
Have you tried resetting Octane Daz to see if it makes any difference?
cheers
Kind Regards
bk3d
filipe_sheepwolf
Hello.
Is the "TEMPLATING" feature not working? It refuses to load textures from the Iray materials, even after I choose one in the "primary source" option (same for "alternate" and "fallback" options)
I even tried using the Octane Render Kit collection available in the Daz store, but the materials it comes with just don't work either (the ones with the TEMPLATING feature just show a black or white texture, even though they should be loading the textures from the original objects they're applied to)
So far it's not working with any figure (g8, g9) or prop I tried...
Sorel
filipe_sheepwolf wrote: Fri Aug 08, 2025 5:14 pm Hello.
Templating is working on my end. Can you post some screenshots?
Return to “DAZ Studio”
