Hey paul,
Is it possible to have each setting menu and its own window?
I find myself jumping from tab to tab a lot.
And it would be easier to have each setting menu in its own individual window.
But a solution could be to implement node-graph on settings as well.
That would make things easier. Especially when trying to learn the Standalone more so.
And also I noticed in the node-Graph editor. That I can't seem to undo any changes I make. Is undo unavailable in the node-graph Editor?
UI Window Feature
- spartan00j
- Contact:
Win 11
Ryzen Threadripper 2950X
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
Hi - Splitting each tab into it's own UI panel would be possible, but a lot of work, so not something I would look at in the near term. And no, unfortunately the NodeGraph edit does not have an undo feature.spartan00j wrote:Hey paul,
- spartan00j
- Contact:
Okay, what about applying the node graph feature to the render Target settings then.face_off wrote:Hi - Splitting each tab into it's own UI panel would be possible, but a lot of work, so not something I would look at in the near term. And no, unfortunately the NodeGraph edit does not have an undo feature.spartan00j wrote:Hey paul,
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
This is not really possible - the idea of displaying the NodeGraph window is so that you can see how the plugin has transferred the Poser scene to Octane. It is not intended for updating settings - sorry.Okay, what about applying the node graph feature to the render Target settings then.
- spartan00j
- Contact:
okay Thanksface_off wrote:This is not really possible - the idea of displaying the NodeGraph window is so that you can see how the plugin has transferred the Poser scene to Octane. It is not intended for updating settings - sorry.Okay, what about applying the node graph feature to the render Target settings then.
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
- spartan00j
- Contact:
Hey Paul,face_off wrote: Sun Aug 28, 2022 11:02 pmThis is not really possible - the idea of displaying the NodeGraph window is so that you can see how the plugin has transferred the Poser scene to Octane. It is not intended for updating settings - sorry.Okay, what about applying the node graph feature to the render Target settings then.
I know you said this was impossible a few years ago. But it seemed like the impossible happened.
Has that changed?
Because I went into the node-grab editor for a material. And it opened up not only the material but the render target settings as well.
But I can see the render target in the node graph editor of the plug-in. See my screenshot.
And changing the settings in the note graph on the render target. Changed the settings in the Poser scene.
Seems like it was some kind of glitch. I can't seem to recreate it. But it did work.
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
It looks like there is a bug in the plugin nodegraph code where if you open the nodegraph a second time, it is referring to the first nodegraph, which may not exist anymore. This is something I need to fix - it is happening with some of my other plugins too.Seems like it was some kind of glitch. I can't seem to recreate it. But it did work.
- spartan00j
- Contact:
As a lyric from a song by VEAUX- (It's Not A Bug, It's A Feature)face_off wrote: Thu Jul 31, 2025 11:29 amIt looks like there is a bug in the plugin nodegraph code where if you open the nodegraph a second time, it is referring to the first nodegraph, which may not exist anymore. This is something I need to fix - it is happening with some of my other plugins too.Seems like it was some kind of glitch. I can't seem to recreate it. But it did work.
Can we make this a feature?
I would like to edit the render target using the node-graph feature. Or possibly the whole scene. It's just more fluid than using tabs.
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
Unfortunately this is not possible. There are too many things you can do in the nodegraph that would break the Poser plugin tree structure - sorry.I would like to edit the render target using the node-graph feature. Or possibly the whole scene. It's just more fluid than using tabs.
- spartan00j
- Contact:
Okay, I understand.
Win 11
128GB RAM
RTX 3060 TI
128GB RAM
RTX 3060 TI
