make a mesh invisible to camera?
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
Dingbat
can't find the check box for mesh visibility
can we do this in AC?
e.g. i want to make a wall invisible but still have it block light
frankmci
I haven't specifically used the ArchiCad plugin, but if you have the RayType or RaySwitch Utility nodes, they should let you turn off Camera Rays while leaving Shadow Rays active. If you don't explicitly have those nodes in ArchiCad Octane, take a look at the RayType.OSL shader discussion threads here on the forums a few years ago. I think it was around 2020 or 2021. Ah, found a few:
viewtopic.php?f=21&t=71597
viewtopic.php?f=87&t=67849
Shadow Caster
Shadow Caster
Dingbat
thanks but there's no access to nodes at all in AC (afaik)
frankmci
Dingbat wrote:thanks but there's no access to nodes at all in AC (afaik)
Ouch. Sorry to have mislead you. If ArchiCad supports single sided polygons or polygons with different materials on each side, you might be able to use ssps or dual materials per poly to act sort of like one way glass, blocking light from one direction but letting it pass from the other. It does the trick in certain situations, but a lot depends on your particular lighting and POV.
Dingbat
no worries
not sure if AC supports single sided polys - can someone confirm?
and if this is possible, does anyone know a quick way to flip a poly in AC (or through Octane)?
Dingbat wrote:not sure if AC supports single sided polys - can someone confirm?
I am guessing here....but a polygon in Octane (and AC) is double sided with a Normal vector pointing out. If you attach a "Polygon Side" node to the opacity pin of the material of a polygon, then it effectively becomes single sided. https://docs.otoy.com/standaloneSE/PolygonSide.html
Dingbat wrote:and if this is possible, does anyone know a quick way to flip a poly in AC (or through Octane)?
I don't think you could flip a single polygon in Octane.
Dingbat
thanks Paul - so close but in this specific case not quite
Polygon Side works but not in Clay render mode
there's also an 'Invert' option to invert the polygons
so it does work but not in Clay mode which of course is what i need right now...
Dingbat
although Polygon Side does work in MODO in clay mode, so maybe it's a bug in AC if it doesn't work there?
Polygon Side works in Colored Clay mode, but not Clay Mode. In theory, the Clay Mode in ArchiCAD should be the same as Modo.
Dingbat
hi Paul,
does that mean it's an easy fix?
Return to “Graphisoft ArchiCAD”
