Mesh UV projection problem
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
HHbomb
I have a material with a texture with a projection "Mesh UV projection" set to 3.
Each time I open my scene, the projection isn't applied. I need to change the value in the node ( 3 to 2 then 2 to 3 ) then the projection is applied. :evil:
note : UVW MAP modifier applied to the objects is instanced.
Thanks !
neonZorglub
HHbomb wrote:Hi,
The attachment pbuv.JPG is no longer available
Thanks !
Hi HHbomb,
I couldn't reproduce the issue.
It seems to work fine..
Here is a sample scene with the uv set to 1,2,3 and mixed on several boxes..
UVSet123_sample.zip
(1.18 MiB) Downloaded 159 times
You may have other settings that prevent the correct initialization at load time ..?
Could you post a sample scene ?
HHbomb
It seems that it is a problem with normal maps.
PBNM1.zip
(342.3 KiB) Downloaded 160 times
when I open the scene, I have the left render, it I change the value of the Map#399 ( from 3 to 2 then 2 to 3 ) I get the render of the right.
Hope the max file can help. :-)
HHbomb
bump
neonZorglub
HHbomb wrote:Hi,
PBNM1.zip
Hi HHbomb,
Sorry for the delay.
Thanks a lot for the scene. I could see the problem.
The issue will be fixed in the next release.
Return to “Bug Reports”
