Lens effects causes render failure
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
LA59494
Hi there,
I found that the lens effect features (Chromatic aberration or lens flare intensity) causes a render failure if higher than 0. When I reset it to 0 the LV/Render will work normal again.
Post Processing works normal. Running the latest MacOS Standalone and the latest stable C4D Plugin on my Macbook M2 Max (on 13.6).
Lars
Hi Lars,
sorry but I cannot reproduce the issue here on macOS with latest 2023.1.3 stable version, both Chromatic Aberration and Lens Flare are working as expected in both Live View and Picture Viewer:
Please go to c4d menu Extensions/Console, (Shift+F10), and share a complete screenshot of the panel, or copy paste the default console output in your answer, thanks.
ciao,
Beppe
LA59494
Hi Beppe,
here's my console. I tried to resend it three times. Every time the console and log pops up.
Loaded Octane DLL:Octane X Prime 2023.1.2  version:13000200  SDK:2023.1.2
Octane X for Cinema 4D 2023.1.2-[R7]  built for:20230   C4D vers:2023200
C4D:2023200  comp:[Lars’ MacBook Pro]  OS:[OS X 64 BIT] macOS: Version 13.6 (Build 22G120)  versType:10
CPU:[]  speed:0 GHz  numOfCpu:12
Plugins:[addons advanced_render alembic analytics archigrass assetbrowser bitmapfilter bpexchange browser bugslife_client c4d_emulation c4d_viewport_render c4dOctane-R2023 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deltamush deployment dwg dwgobjects dynamics exchanges expressiontag fbx gltf goz hair i_skp interop interop_forger io_forger io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor2 objects pbd_simulations physx_hybrid projectassetinspector python redshift relaxuv scenemanager2 sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking_particles tool_system_hybrid tpoperators usd uvviewport volumes xpressocore xtensions redshift4c4d ]
Loaded 175 osl scripts from dir:/Applications/Maxon Cinema 4D 2023/plugins/OctaneRender/res/osl_scripts
initOCIOconfig     cfgFile:    OCIO_ENV:
VRAM used/free/max:0Kb/32Gb/32Gb  Out-of-core used:0Kb  RAM used:20.03Gb total:32Gb  OpenGL free/total:0/0
Export materials time= 0.032 ms
Collect objects time= 0.022 ms
Mesh creation time = 1.006 ms.
Api update time: 0.022 ms.
VRAM used/free/max:1.252Gb/30.748Gb/32Gb  Out-of-core used:0Kb  RAM used:20.37Gb total:32Gb  OpenGL free/total:0/0
File not found:/Users/larsallenberg/Library/Preferences/Maxon/Maxon Cinema 4D 2023_3BE69839/updates2020.txt
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
 MB:0/0  ST/MOV:0/0  Nodes:13  Tris:0  DispTris:0  Hairs:0  Meshes:1
OCT: MB:0/0  ST/MOV:0/0  Nodes:13  Tris:0  DispTris:0  Hairs:0  Meshes:1
 Textures Grey8/16:0/0  Rgb32/64:0/0
OCT: Textures Grey8/16:0/0  Rgb32/64:0/0
>> ProcessUpdate(flags=CM cAsyn=1 dDelay=1
>> ProcessUpdate end res:0 tm:0.004ms.
OCT:--------------------------- EXPORT LOG ---------------------------
ResetAndInit 1
ResetAndInit [OK]
Export materials time= 0.018 ms
Collect objects time= 0.012 ms
Mesh creation time = 0.217 ms.
Api update time: 0.025 ms.
 MB:0/0  ST/MOV:0/0  Nodes:12  Tris:0  DispTris:0  Hairs:0  Meshes:1
OCT: MB:0/0  ST/MOV:0/0  Nodes:12  Tris:0  DispTris:0  Hairs:0  Meshes:1
ResetAndInit 1
ResetAndInit [OK]
Export materials time= 0.019 ms
Collect objects time= 0.013 ms
Mesh creation time = 0.535 ms.
Api update time: 0.014 ms.
Lars
Screenshot
Screenshot
Hi Lars,
ok, please also share a screenshot like this one, that shows both c4doctane directory opened, and the entire installation path, thanks:
ciao,
Beppe
LA59494
Hi Beppe,
this looks pretty much the same. Only difference is I renamed the folder to "OctaneRender" to shorten the long default name in the C4D extensions. But I handled it before like that and lens flare was working.
Best,
Lars
Finder
Finder
Hi Lars,
ok, please close C4D, then change the name of the folder from "Plugins" to "plugins" in lowercase:
ciao,
Beppe
LA59494
Hi Beppe,
changed the folder name but no difference. Been on 2023.1.2-R7 when posting this thread and updated to 2023.1.3-R2 today but the issue is still present. Think I have been on 2023.1.2-R3 before R7 and will go back for now.
Lars
Weird, I cannot reproduce the issue with both 2023.1.2-R7 and 2023.1.3-R2.
Ok, please write to help at otoy dot com asking for Beppe, thanks.
ciao,
Beppe
LA59494
Hi Beppe,
Ricky reached out to me and we figured what's going on. When the LVs resolution is odd (non-power of 2) there will be a render failure when lens features are used. When I lock the resolution to an even number it works fine.
Best,
Lars
Hi Lars,
yes, it is a core issue, great that Ricky found it out!
ciao,
Beppe
Return to “Bug Reports”
