Hi, where is the 20.0.547 version?
The last one that is supported here, is the previous stable build
OctaneRender 2023.1 for Houdini production (2023.1.0.2)
- PDivision1
We are planning to release it early next weekthanulee wrote:Hi, where is the 20.0.547 version?
Has anyone else seen a regression in Mplay snapshot behaviour under OCIO v2 or just me? It seems to be baking in the view transform again? I need to set Mplay to RAW to match my QT5 Renderview.
Also will the next release fix the crash on close when having the QT5 renderview docked in a pane?
Windows 11 | 14900k | 2 x 4090 | 96gb DDR5.
- ricky_otoy
Hey Adrian, no I’m not aware of a regression in Mplay but I will investigate and get back to you, thank you!adrianr wrote:Has anyone else seen a regression in Mplay snapshot behaviour under OCIO v2 or just me? It seems to be baking in the view transform again? I need to set Mplay to RAW to match my QT5 Renderview.
The docked QT5 window issue has been fixed and it should be in the build to be released early next week.
Thanks for the reply. I dont know if it is a limitation or if i am missing something, but I cannot use octane scatter on a vellum grain simulation. Any tips?
- ricky_otoy
When is that happening, do you have a scene to reproduce this? Do you have the same issue in 2023.1.0.3?mttsapov wrote:Regarding the errors like: "Invalid parameter name globalLightIdMask_17" i'm getting that in 20.0.547 and the matching version of Octane, is there a way to fix it?
Hi, yes i can reproduce it every time i open my IPR.ricky_otoy wrote:When is that happening, do you have a scene to reproduce this? Do you have the same issue in 2023.1.0.3?mttsapov wrote:Regarding the errors like: "Invalid parameter name globalLightIdMask_17" i'm getting that in 20.0.547 and the matching version of Octane, is there a way to fix it?
Even when i do a Full Reload or an Update from the IPR window
