OctaneRender 2023.1 for Houdini production (2023.1.0.2)
Forums: OctaneRender 2023.1 for Houdini production (2023.1.0.2)
Re: OctaneRender 2023.1 for Houdini production (2023.1.0.2)
Postby thanulee » Thu Dec 14, 2023 6:37 pm
thanulee Thu Dec 14, 2023 6:37 pm
Hi, where is the 20.0.547 version?
The last one that is supported here, is the previous stable build
thanulee
Postby PDivision1 » Thu Dec 14, 2023 7:19 pm
PDivision1 Thu Dec 14, 2023 7:19 pm
thanulee wrote:Hi, where is the 20.0.547 version?
We are planning to release it early next week
PDivision1
Postby adrianr » Thu Dec 14, 2023 9:59 pm
adrianr Thu Dec 14, 2023 9:59 pm
Has anyone else seen a regression in Mplay snapshot behaviour under OCIO v2 or just me? It seems to be baking in the view transform again? I need to set Mplay to RAW to match my QT5 Renderview.
Also will the next release fix the crash on close when having the QT5 renderview docked in a pane?
adrianr
Postby ricky_otoy » Fri Dec 15, 2023 7:54 am
ricky_otoy Fri Dec 15, 2023 7:54 am
adrianr wrote:Has anyone else seen a regression in Mplay snapshot behaviour under OCIO v2 or just me? It seems to be baking in the view transform again? I need to set Mplay to RAW to match my QT5 Renderview.
Hey Adrian, no I’m not aware of a regression in Mplay but I will investigate and get back to you, thank you!
The docked QT5 window issue has been fixed and it should be in the build to be released early next week.
ricky_otoy
Postby thanulee » Fri Dec 15, 2023 7:53 pm
thanulee Fri Dec 15, 2023 7:53 pm
Thanks for the reply. I dont know if it is a limitation or if i am missing something, but I cannot use octane scatter on a vellum grain simulation. Any tips?
thanulee
Postby mttsapov » Fri Jan 19, 2024 12:14 pm
mttsapov Fri Jan 19, 2024 12:14 pm
Regarding the errors like: "Invalid parameter name globalLightIdMask_17" i'm getting that in 20.0.547 and the matching version of Octane, is there a way to fix it?
mttsapov
Postby ricky_otoy » Fri Jan 19, 2024 2:07 pm
ricky_otoy Fri Jan 19, 2024 2:07 pm
mttsapov wrote:Regarding the errors like: "Invalid parameter name globalLightIdMask_17" i'm getting that in 20.0.547 and the matching version of Octane, is there a way to fix it?
When is that happening, do you have a scene to reproduce this? Do you have the same issue in 2023.1.0.3?
ricky_otoy
Postby mttsapov » Sun Jan 21, 2024 6:10 pm
mttsapov Sun Jan 21, 2024 6:10 pm
Hi, yes i can reproduce it every time i open my IPR.
Even when i do a Full Reload or an Update from the IPR window
mttsapov
Previous
Return to Releases
Sun Jun 16, 2024 5:17 am [ UTC ]
