Houdini production builds supported by this release: 19.0.720, 19.5.534, 19.5.569, 19.5.605 - 19.5.805, 20.0.506.
If you are not sure if your Houdini version is compatible with the plugin - just run it and you will see an error message in case of incompatibility.
Linux Note
On Linux only compatibility Houdini 20 build is supported (gcc9.3).
It can only be installed by downloading it from the downloads page since it's not visible in the Launcher:
https://www.sidefx.com/download/daily-b ... ction=true
or direct download link: houdini-20.0.506-linux_x86_64_gcc9.3.tar.gz
We are looking into supporting the gcc11.2 build.
New features
To learn more about the new features and improvements of OctaneRender 2023.1, please check out the 2023.1 release post
Known bugs
On Linux, MPlay IPR may not be working. If you are having problems with it, please switch to QT5 IPR and disable "Render to MPlay" in ROP nodes.
Downloads
Release 2023.1.0.2 Studio+ license
Windows Houdini 19.0.720 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 19.5.534 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 19.5.569 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 19.5.605 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 19.5.805 - https://render.otoy.com/customerdownloa ... _Win64.zip
Windows Houdini 20.0.506 - https://render.otoy.com/customerdownloa ... _Win64.zip
Linux Houdini 19.0.720 - https://render.otoy.com/customerdownloa ... dio%2B.zip
Linux Houdini 19.5.534 - https://render.otoy.com/customerdownloa ... dio%2B.zip
Linux Houdini 19.5.569 - https://render.otoy.com/customerdownloa ... dio%2B.zip
Linux Houdini 19.5.605 - https://render.otoy.com/customerdownloa ... dio%2B.zip
Linux Houdini 19.5.805 - https://render.otoy.com/customerdownloa ... dio%2B.zip
Linux Houdini 20.0.506 - https://render.otoy.com/customerdownloa ... dio%2B.zip
Release 2023.1.0.2 macOS Prime license
MacOS Houdini 19.5.534 - https://render.otoy.com/downloads/48/b7 ... _Prime.zip
MacOS Houdini 19.5.569 - https://render.otoy.com/downloads/a5/07 ... _Prime.zip
MacOS Houdini 19.5.605 - https://render.otoy.com/downloads/7d/36 ... _Prime.zip
MacOS Houdini 19.5.805 - https://render.otoy.com/downloads/e8/3e ... _Prime.zip
MacOS Houdini 20.0.506 - https://render.otoy.com/downloads/ce/86 ... _Prime.zip
Release 2023.1.0.2 Demo version
Windows Houdini 19.0.720 - https://render.otoy.com/plugindownloads ... _Win64.zip
Windows Houdini 19.5.605 - https://render.otoy.com/plugindownloads ... _Win64.zip
Windows Houdini 19.5.805 - https://render.otoy.com/plugindownloads ... _Win64.zip
Windows Houdini 20.0.506 - https://render.otoy.com/plugindownloads ... _Win64.zip
Linux Houdini 19.0.720 - https://render.otoy.com/plugindownloads ... x_Demo.zip
Linux Houdini 19.5.605 - https://render.otoy.com/plugindownloads ... x_Demo.zip
Linux Houdini 19.5.805 - https://render.otoy.com/plugindownloads ... x_Demo.zip
Linux Houdini 20.0.506 - https://render.otoy.com/plugindownloads ... x_Demo.zip
Release Notes
RELEASE 2023.1.0.2
* PLUGIN FEATURES AND FIXES:
- Fixed Deadline submission issues (revereted change in the HO_img_fileFormat parameter)
Note: you may get incorrect output files extension when using TIFF or JPEG formats (these formats were recently added and Deadline scripts are not aware of them yet). If it happens to you, please send a ticket to the Deadline support so that they fix it in the next release.
Since the parameter was reverted, you may see the error message when opening files saved with plugin version 2023.1.0.0 (ROP's image file format will be reset to png).
- Fixed bug with ROP's file format being always reset to PNG when opening files
- Fixed a crash when switching multiple ROPs
- Fixed tessellate ngons produces additional polygon from curves
- Fixed regression in gradient ramps when the first and last control point wasn't working correctly
- When changing "interpolation type" dropdown, it will also change the "interpolation" of all the gradient control points to the closest one (only affects the gradient preview so that it looks closer to what you would see in the octane standalone)
Common Issues and Solutions
- If the plugin doesn't work at all, set
HOUDINI_DSO_ERROR = 2 in houdini.env and check for messages in the terminal.- If you're missing
libglut.so.3, install the freeglut package.- If you are having any issues with the Deadline - please submit a support ticket to the AWS.
Happy rendering,
Your OTOY Team
