Thank you for the reminder. I have already deleted the extra components before that.frankmci wrote:You might double check the Octane plugin folder to make sure all non-C4D 2023 components have been deleted.wangdanyang1120 wrote:After installing Octane 2023.1-R7, I am unable to launch C4D. The C4D version is 2023.2.1.It consistently gets stuck at 'Initializing plugins 100%.
Everything was functioning normally with Octane 2023.1-R6.
Cinema4D version 2023.1-[R7] (Obsolete stable) 25.11.2023
- wangdanyang1120
There's also the "plugins in the app directory vs the preferences directory" thing. That has bitten me more than once. Maxon's attempt to force standardization of that several versions back seems to have failed.wangdanyang1120 wrote: Thank you for the reminder. I have already deleted the extra components before that.
Please see attached video how Quixel Bridge creating Octane materials in C4D with default gamma 2.2 for translucency.DinoMuhic wrote: Sorry I dont have an account at Graswald but I tested it with Quixel Megascans assets and there the translucency map also has to be interpreted lineary (1.0 Gamma) to look correct.
Please repair.
- Bridge_Oct_Mat.zip
- (1.16 MiB) Downloaded 201 times
- SilentPartnersStudio
Note sure if it has been mentioned, but if you set the area light to a disc shape, the direction of illumination flips to negatize z, instead of positive z.
yes, Disk primitive is only supported by new Analytic light:SilentPartnersStudio wrote:Note sure if it has been mentioned, but if you set the area light to a disc shape, the direction of illumination flips to negatize z, instead of positive z.
viewtopic.php?f=85&t=82023&p=427165&hilit=disk#p427165
ciao,
Beppe
It's interesting, because it is in the documentation, and it works fine if I flip the scale negative on the z axis.bepeg4d wrote:yes, Disk primitive is only supported by new Analytic light:SilentPartnersStudio wrote:Note sure if it has been mentioned, but if you set the area light to a disc shape, the direction of illumination flips to negatize z, instead of positive z.
ciao,
Beppe
So seems supported, but broken...
sorry, that image was made when only default light mode was available.
Octane lights are differently optimized for AI Lights, depending on the type:
- Default = only Rectangle
- Use primitives = Rectangle, Sphere
- Analytic = Rectangle, Sphere, Disk, Tube
You can use the Default or Primitive modes with Disk Area Light, but it is like using a Disk object with Diffuse Emitter material.
Note that in Default and Primitive mode, you can see the segments of the disk. ciao,
Beppe
Beppe
Correct.bepeg4d wrote:Hi,
Beppe
And when I do this, the direction is reversed.
both the same: disc rotated +180:
