Cinema4D version 2023.1-[R7] (Obsolete stable) 25.11.2023
Hi all,
This is the plugin build based on 2023.1 stable SDK. Any feedback will be much appreciated. Enjoy it!
This is the Standalone matching Standalone 2023.1.
Make sure to use a NVIDIA Studio driver with version at least 456.38 on Windows.
Important: if using macOS, we strongly recommend that for macOS, you use at least 13.3 or preferably newer.
1- Use NVIDIA STUDIO drivers, not Game Ready versions. If you have stability issues try different drivers, some of them could cause instability issues. Make a clean install while doing this to be sure previous files completely removed.
2023.1-R7 plugin revisions
  • Slider adjustments for Output AOV nodes, some fixes on several UI
  • Motion blur support for Cloner/Multi-instance mode and sub-steps support
  • Added switch texture
  • Fix: display to PV's render buffers(olders than R20)
  • Fix: material connection to SDF meshes
2023.1-R6 plugin revisions
  • Enable options for composite material
  • Octane materials menu in Material Manager
2023.1-R5 plugin revisions
  • Improvements/fixed on Output AOVS
  • Fix: a crash case with Hair object in C4D 2024
2023.1-R4 plugin revisions
  • C4D light linking is now working with Analytic lights
  • Compare mode is now can better display the all passes
  • Fix: a crash case on Scatter object on C4D 2024 builds
  • Re-work on output AOVs to use some new nodes. Dropped some old nodes by marking as deprecated.
  • Fix: wrong group info when nodes are duplicated
  • Fix: a crash on deleting some ORBX loaders in C4D 2024
2023.1-R3 plugin revisions
  • Crash on Scatter+effectors on C4D 2024.1.0
  • Minor fixes in some parameters
2023.1-R2 plugin revisions
  • Added DWA compression parameter for saving Octane-EXR files
  • Fix: PostFX Media AOV
  • Fix: LV update issue for some content on C4D 2024
  • Fix: Ignoring PBR import when an image file frop over any Image Texture
  • Fix: Wrong orientation on Area lights when unsupported shape used with primitives option
  • Fix: Cylinder Analytic light orientation
2023.1 plugin revisions
  • Fix: Endless refresh issues when stacked material used together with Vertex Map Tags
  • Now camera-mapping in texture that is supporting "Film Offset" values from Camera.
  • Fix: Custom LUT list
  • Offset parameter in shape field
  • Added Null material
WINDOWS STUDIO+ 2023.1-[R6] (R15-R2024)
https://render.otoy.com/customerdownloa ... R7_win.rar
WINDOWS STUDIO+ DEMO 2023.1-[R6] (R15-R2024)
https://render.otoy.com/plugindownloads ... R7_win.rar
Mac OSX Prime 2023.1-[R6] (R25-R26/R2023/R2024)
https://render.otoy.com/plugindownloads ... R7_OSX.zip
Please note the macOS build below will only work correctly on macOS 13.3 and newer, and only on Apple Silicon.
Requirements:
-You'll need to update your Cinema 4D to latest versions(R16.050, R17.053, R18.057, R19.053, R20.057, R21.115, S22.118, R23.110, R24.111, R25.117, R26.107, R2023.2). Otherwise, the plugin will not work and not appear in menus.
-Nvidia drivers at least Nvidia Studio Drivers(minimum 456.38) and be careful with latest Game Ready drivers which can cause cuda errors. Stay with stable one for you.
ONLINE HELP MANUAL
or from link: https://docs.otoy.com/cinema4d/OctaneRe ... ema4D.html
Installation
Ex. if you have Cinema4D R2023, keep only "c4dOctane-R2023.xdl64" and delete c4dOctane-R26.xdl64, c4dOctane-R25.xdl64, c4dOctane-R24.xdl64, c4dOctane-R23.xdl64, etc..
Kalua
Really quick!
Thanks, Aoktar!
C4D 2026.1 v1.8.2 // Octane 2026.1, <<2 X 3090 + NVlink>>, Windows 11 Pro, X399, AMD TR 2950X, 128 GB RAM, NVIDIA SD 560.94
Octane User since V1 Beta
JEEK
Thank you for the fast turnaround aoktar!
I'm getting an error when extracting "OctaneStudio-for-C4D-2023.1_win.rar" on Windows 11 Pro 22H2 (OS build 22621.2428). See the attached image.
That said, I get no error when unzipping the .RAR file with 7zip.
zomtech
Very nice! Thanks for continuous stellar work Aoktar!
Right now it seems like older scenes using octane scatter crash when opened in C4D 2024.1 with Octane 2023.1
Windows 10 | 1x 4090, 4x 3090 | 13900K | 128Gb
twik25
Thanks for making this so quickly! It looks like the PostFX Media AOV is missing from Render AOVs.
twik25 wrote:Thanks for making this so quickly! It looks like the PostFX Media AOV is missing from Render AOVs.
Sorry it's missed so, I'll add for next one.
zomtech wrote:Very nice! Thanks for continuous stellar work Aoktar!
My test scenes are working well. Please share the crashing scene by PM
JEEK wrote:Thank you for the fast turnaround aoktar!
That said, I get no eror when unzipping the .RAR file with 7zip.
No problem here!
scaprendering
Great update, most new features from Stadalone are working great.
I'm still having this Mesh to SDF and volume SDF issue with vectron operators that does not work at all, only union kind of works (Try to subtract vectron and volume SDF with VectronOP).
It would be delicious to have a custom OSL VectronOP node instead of "Baked" union, subtraction and intersect, for instance here's intersection :
#include "octane-oslintrin.h"
shader CustomOperators(
    _sdf FirstVectron = _SDFDEF,
    _sdf SecondVectron = _SDFDEF,
    output _sdf c = _SDFDEF)
	c.dist = max(FirstVectron.dist, SecondVectron.dist); //Do whatever you want with two vectron/SDF inputs
And here's intersection from Cinema 4D (almost invisible effect)
More advanced setup in standalone :
Correct Octane custom OSL equivalent of C4D intersect vectron OP :
Multiple boole combination (like volume denting) in standalone:
Hope this can be implemented correctly and match the standalone 2021 as it's really powerful and unique! Thanks
Well, it's working well on 2024.0.1. But crashing on 2024.1.0, cool!
SSmolak
XPresso still doesn't update in realtime objects, material nodes like Transform and others. You should do the same for materials and objects as you did for Camera and Sky object before for C4D 2024 version.
Please see - horizontal doesn't work realtime because it is connected to transform material node, vertical works because it is connected to object.
xpresso_object_material_issue.rar
(699.8 KiB) Downloaded 191 times
Kalua
I see the new "Null Material".
However I don't see the transmission and Geometry Properties in the Material editor window.
They appear in the attribute manager window though.
Some settings are making it behave funny... looking like a toon shader??
Regards!
