Cinema4D version 2022.1.1-R6 (Obsolete stable) 08.07.2023
miohn
z
aoktar wrote:
miohn wrote: every object in the viewport whis has an octane material appears black.
So I have a stage-object and 2 other objects on the stage (f.e. my startscene "new.c4d") and all is black
The attachment Startscene.jpg is no longer available
Your viewport is fully filled by objects, so viewport is not black. Covered objects are with black textures. Spend some time to play with content to gather more info.
come on!
As I said two times: objects with octane material applied are displayed black in the viewport
Hope these screenshots are understandable now. ;)
All was fine before I updated to 2023.2.2.
Now I'm back to 2023.2.1 but this problem is still present!
I cannot work proberly when I cannot see anything in the viewport, because all objects are displayed black.
Is'nd there a workaround for that?
thanks
Mike
miohn wrote:
z
come on!
Delete oct.dat while C4D not open, it's in prefs folder. And START C4D
thanks
Mike
miohn
just that simple!
Deleting the "oct.dat" solved it!
Thanks very much!
Mike
SSmolak
Will it be added to C4D Octane version ( more options for mesh to SDF conversion ) ?
wangdanyang1120
miohn wrote:Hi there,
what was again the problem, if octane never finishes a rendering?
Thought there was a solution for that problem, but I don't remember.
Render is ready, but status still saying "Render progress..." and it never stops/saves.
"Show Passes" already disabled!
regards
Mike
May I ask if this problem has been resolved? I am deeply troubled by it and can only use the R26 version now
wangdanyang1120
aoktar wrote:
blackcat321 wrote:I have encountered a serious problem where the image cannot be stored after rendering is completed, and closing the picture viewer will result in c4d not responding.
I tested with many different projects, and they all trigger bugs, especially when a project renders output for the second time (output overwrites the previous image), it will appear 100%
c4d 2023.2.1
rtx4090
drive 535.98
It's happening on some setups when render AOVs are used. Work around is to disable the "show passes" parameter
If I disablethe "show passes" parameter, rendering can proceed, but the output image will not have Denoised beauty.
c4d 2023.2.1
rtx4090
drive 535.98
It's a new issue after C4D update on some CPU types. What's your CPU?
SSmolak
Another issue using SDF created from Volume Builder :
field_sdf_0002.zip
(414.68 KiB) Downloaded 129 times
Toche
aoktar wrote: It's happening on some setups when render AOVs are used. Work around is to disable the "show passes" parameter
If it helps, I'd like to give you my CPU type too because I'm having the same issue (but no C4D crash for me): Intel 9900KS
Even trying with and without "Show Passes", in "EXR (Octane) or "EXR", trying compression other than DWAA/DWAB... I still haven't found the right combination to get all my passes and the denoised beauty.
freeter_e
feedback: material tag exchange, not update
thanks
C4D 2023.2.1
Octane 2022.1.1-R5
material tag exchange, not update.mp4
(2.85 MiB) Downloaded 1858 times
Return to “Releases”
