OctaneRender® 2023.1 Alpha 1
Amaterasu
Please explain how to use this setting, it should give the effect of the rays of light sources, but nothing like this happens, I would be glad if you tell me what I do wrong, thank you
J.C
Amaterasu wrote:Please explain how to use this setting, it should give the effect of the rays of light sources, but nothing like this happens, I would be glad if you tell me what I do wrong, thank you
From my first experiences with Octane 2023 you need to use new Analytic lights for this.
System – Windows 11
eyeonestudio
J.C wrote:Enabling "Fog environment contribution" results in funky image.
The attachment Render target.png is no longer available
Fog Environment Contribution --> Lower Value
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
J.C
What is the correct use of "Fog Environment Contribution"?
System – Windows 11
J.C
elsksa wrote:
J.C wrote:Can somebody explain why there are two BRDF options in Glossy and Universal material node and how to use it?
One is for the "diffuse" reflection,
the other the "specular" reflection.
Lambertian vs Oren Nayar (vs Octane's own model) differences can be found on an other release note post or online.
So the "Oren Nayar" is now a default mode for diffuse surfaces?
If I want previous behaviour Should I use "Octane"?
System – Windows 11
john_otoy
Can you provide a simplified scene? You can replace the car with a cube, as long as the problem still happens.
J.C
I've sent PM as you asked.
System – Windows 11
J.C
elsksa wrote:
J.C wrote: So the "Oren Nayar" is now a default mode for diffuse surfaces?
"Whatever floats your boat".
Thanks for detailed explanation. I already knew about those BRDF differences. My only concern was BRDF modes were not present for Diffuse (but only for reflection) in 2022 builds so I wondered what settings should I keep to have same look as before.
System – Windows 11
hypeng
Hi there,
You will need to create an analytic/directional light in the scene and toggle on the `User in post volume` bool pin for it to show up in the post volume pass.
nuno1980
I request you will increase the number of samples per pixel from 1M to 100M for any region picked (and/or for full image) and add the "Max. samples for region picked:" for kernel settings due to the very good/excellent (variable and fixed) caustics at Path Tracing in next version of 2023. :)
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
