Big thanks guys for sharing your results :D
Here is the updated chart:
Happy Mac GPU rendering!
ciao,
Beppe
nuno1980
Hello. Sorry, I don't have any Apple Mac desktop/laptop :) but...
...I've a GPU Zotac GeForce RTX 4090 Trinity non-OC@stock with GF 527.56WHQL driver running Windows 10 (operating system) and CPU Intel Core [email protected] and 2x16GB DDR4-3600 and I got 3 seconds (almost 40 MS/s) using OR 2022.1 :D but only up to 1002x602 resolution rendered :( due to "demo". lol ;)
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
Hi Rodrigo :D
I know you couldn't resist :D
But, how much Power/Watt do you need for your beast while rendering?
I'm talking about the entire machine power consumption, not only the GPU.
Please consider that M1 Ultra Mac max power consumption is 215W.
ciao,
Beppe
nuno1980
bepeg4d wrote:Hi Rodrigo :D
ciao,
Beppe
I'm Rodrigo!??? No, but yes Ricardo Rodrigues or @nuno1980. :)
My GPU RTX 4090 got 270W and my PC system (CPU [email protected]...) 350~400W while benchmarking. My this GPU rendering got only
almost 45 ºC at full load during many minutes at my room of 17 ºC. :)
Caustics at PT
i7-12700KF
32GB DDR4@3600
altestudio
I was using Octane in C4D on my macbook metal fine but suddenly this file will no longer open, can anyone help explain why?
Started logging on 08.02.23 14:23:52
Octane X Prime 2022.1 (12000020)
OCIO config file:/Users//Library/CloudStorage/GoogleDrive.com/My Drive/_3D/Assets/aces_1.2/config.ocio loaded.
VRAM used/free/max:0Kb/64Gb/64Gb Out-of-core used:0Kb RAM used:18.642Gb total:64Gb OpenGL free/total:0/0
Scene version:12000020
FumeFx library initialisation error!
Export materials time= 1528.636 ms
Collect objects time= 0.348 ms
Mesh creation time = 3.726 ms.
Api update time: 0.105 ms.
Compute error 2097152:6199234486295259741:3348:
Compute error 2097152:6199234486295259741:3348 on device 0:
device 0: path tracing kernel failed
MB:0/0 ST/MOV:0/13 Nodes:58 Tris:9k DispTris:12k Hairs:0 Meshes:14
Textures Grey8/16:0/0 Rgb32/64:5/5
Loaded Octane DLL:Octane X Prime 2022.1 version:12000020 SDK:2022.1
Octane X for Cinema 4D 2022.1-[R3] built for:20230 C4D vers:2023001
C4D:2023001 comp:[MacBook Pro] OS:[OS X 64 BIT] macOS: Version 12.5 (Build 21G72) versType:10
CPU:[] speed:0 GHz numOfCpu:10
Plugins:[addons advanced_render alembic archigrass assetbrowser bitmapfilter bpexchange browser bugslife_client c4d_emulation c4d_viewport_render c4dOctane-R2023 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deltamush deployment dwg dwgobjects dynamics exchanges expressiontag fbx gltf goz hair i_skp interop interop_forger io_forger io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor2 objects onlineupdater pbd_simulations physx_hybrid projectassetinspector python redshift relaxuv scenemanager2 sculpt sculptbrushes shader sketch sky sla spacemouse teamrender thinking_particles tool_system_hybrid tpoperators usd uvviewport volumes xpressocore xtensions redshift4c4d ]
Loaded 176 osl scripts from dir:/Applications/Maxon Cinema 4D 2023/plugins/c4dOctane/res/osl_scripts
OCIO config file:/Users/howardphillips/Library/CloudStorage/[email protected]/My Drive/_3D/Assets/aces_1.2/config.ocio loaded.
OCT:--------------------------- EXPORT LOG ---------------------------
ResetAndInit 1
ResetAndInit [OK]
checkPathTracing()
create PathTracing
use active CameraImager
checkPathTracing()
create PathTracing
applyPTParams:0x00000003AA508290
ApplyCImager enDenoise:0
******* createMaterials *******
convert mat:[__OctaneTemp__] tip:5703
convert mat:[OctDiffuse3] tip:1029501
convert mat:[OctUniversal4] tip:1029501
convert mat:[OctGlossy6] tip:1029501
convert mat:[OctUniversal3] tip:1029501
convert mat:[OctGlossy5] tip:1029501
convert mat:[OctDiffuse2] tip:1029501
convert mat:[OctUniversal2] tip:1029501
convert mat:[OctUniversal1] tip:1029501
convert mat:[OctGlossy4] tip:1029501
convert mat:[OctMetal1] tip:1029501
convert mat:[OctGlossy3] tip:1029501
convert mat:[OctGlossy1] tip:1029501
convert mat:[OctGlossy2] tip:1029501
convert mat:[OctDiffuse1] tip:1029501
convert mat:[wall] tip:1029501
OCT:Export materials time= 1528.636 ms
OCT:Collect objects time= 0.348 ms
createLightMeshes
OCT:Mesh creation time = 3.726 ms.
Total export Time = 4380.44 ms
OCT:Api update time: 0.105 ms.
File not found:/Users/howardphillips/Library/Preferences/Maxon/Maxon Cinema 4D 2023_3BE69839/updates2020.txt
>> ProcessUpdate(flags=CO cAsyn=0 dDelay=0
checkAllUpdates(flags=CO updFlags=)
createLightMeshes
>> ProcessUpdate end res:1 tm:0.002ms.
createLightMeshes
>> ProcessUpdate(flags=CMOG cAsyn=1 dDelay=1
checkAllUpdates(flags=CMOG updFlags=)
createLightMeshes
<<< Mat checkAndUpdate STARTED >>>
>> ProcessUpdate end res:1 tm:0.007ms.
OCT:Compute error 2097152:6199234486295259741:3348:
OCT:Compute error 2097152:6199234486295259741:3348 on device 0:
OCT:device 0: path tracing kernel failed
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
OCT: MB:0/0 ST/MOV:0/13 Nodes:58 Tris:9k DispTris:12k Hairs:0 Meshes:14
OCT: Textures Grey8/16:0/0 Rgb32/64:5/5
m0dm0d
Some extras for anyone hanging with PR14 for the time being...
iMac i9 5700XT
6800XT (egpu)
6900XT (egpu)
If you did fancy going with combinations of 2x gpus:
5700XT + 6900XT
6800XT + 6900XT
On the move (2022.1) M1:
14" M1 Max 32c 64GB
Not enough reason to change my setup just yet...
But with that said, I'm using RNDR a lot more lately, over rendering locally... the 14" M1 Max feels extremely nippy using the C4D studio plugin (compared to the i9 iMac on PR14 / with any of these egpu combos)... it's much quicker to export ORBX files, with smaller file sizes for RNDR... and lot faster to preview in the live viewer too.
@altestudio: I'm following you via Private Message.
@m0dm0d: big thanks for the new results!
Here is the updated chart, including new Mac Mini M2 Pro:
ciao,
Beppe
spybreak
bepeg4d wrote:@altestudio: I'm following you via Private Message.
The attachment B062244D-021A-4E9C-8614-6AD76E7982F1.jpeg is no longer available
ciao,
Beppe
There is a discrepancy between both M1 Max results. Both of them are 32 core machines, but I provided the 44 second result.
Upon further testing I was able to match the 40 second result by activating the "real time rendering" mode. Not sure if @m0dm0d used that mode, but its the only way I could get the time down from 43-44 seconds to 40.
Screenshot 2023-02-10 at 09.00.33.png (15.14 KiB) Viewed 112856 times
@spybreak: thanks for reporting it!
If Real Time option is enabled, AI Denoiser is not performed so it must be disabled, it is also not available in PR14, so comparison with AMD is not fair.
I have removed the 40" result from the chart, and corrected the M1 base result:
ciao,
Beppe
renatocanton
Is the OctaneX app not working anymore on Mac OS Monterey 12.6.3 (intel)? I have 2 macs and it's not working anymore :|
