Octane Solaris plugin 2021.1.6 - 09 30 22 [OBSOLETE]
peteg
Is the Render Gallery "Background" render feature still being added?
The "Snap" option works great, but the Background render never finishes(I have to stop it manually, max samples are set very low, so it should only take a few seconds) and only creates a black thumbnail. The Background > Live Render option is set to "Octane".
BK
peteg wrote:Is the Render Gallery "Background" render feature still being added?
Hi Pete,
Thanks so much again!
Yeah, the background renders works fine on our workstations.
Would you please send a sample scene? Also are you able to see the render command/task in the Scheduler?
Maybe the hbatch render needs to allow from the Control Panel\All Control Panel Items\Windows Defender Firewall\Allowed apps!
Please let us know if the hbatch is enabled!
cheers
Kind Regards
bk3d
peteg
BK wrote: Hi Pete,
cheers
Manually adding "hbatch.exe" to Windows Defender Firewall Allow list didn't make a difference.
I don't see Background Renders showing up in the "Render Scheduler" for Karma or Octane like rendering from the USD Render ROP does.
Here's one of the scenes I was testing in, along with a screen capture (Background > Live Render > "Karma" Works correctly) -
https://www.dropbox.com/sh/vg1vmocovwtx ... Y88aa?dl=0
It looks like the background render delegates defaults back to Karma each time I open the scene too.
BK
peteg wrote:
BK wrote: Hi Pete,
cheers
Hi Pete,
Thanks again for the video and the file.
My apology, I totally misunderstood as Render to Disk in BG command.
It seems like Karma is set to default render so we need to R-click on the *Background* drop-down and select OctaneRender.
The **hQueue* shows an error code-166 on my workstation, however, the LiveViwer seems to work if we pick Octane.
We would get this hQueue command fixed asap!
cheers!!
Kind Regards
bk3d
peteg
BK wrote: Hi Pete,
cheers!!
Thanks for the reply! Do you have a test scene where the background live render works that I can try? I cannot get this to work for Octane; Karma works as expected.
Background > Live Render > Octane is selected(shown in the screen capture in the previous post), but the render never finishes, only showing a black thumbnail.
BK
peteg wrote:
BK wrote: Hi Pete,
cheers!!
Hi pete,
Thank you so much again!
It is the same file you shared and we just changed the symbol<> to $F4 in the path.
We just noticed that the Octane viewport render process must be stopped before we run the live render.
Please find the video attached
cheers
Alsom
LiveRender.mp4
(13.77 MiB) Downloaded 2096 times
Kind Regards
bk3d
peteg
BK wrote: Hi pete,
cheers
Alsom
Thanks! I'll give that a shot
Terryvfx
Hi, is it possible to compile a new version to work on the latest production release?
Terryvfx
Do anyone else get this error?
yfripp
Terryvfx wrote:Do anyone else get this error?
I got this error when trying octane with the python 3.7 version of Houdini 19.5.368 - It goes away with python 3.9 Houdini 19.5.368
Windows 10 | i7 4770K | Titan X | 32gb
Return to “Releases”
