Octane Solaris plugin 2021.1.6 - 09 30 22 [OBSOLETE]
BK
OTOY® is proud to announce the availability of the new DCC plugin OctaneRender for Solaris V2021.1.6 - for Houdini 19.5.368.
The world's fastest unbiased GPU rendering engine on CUDA and Metal now integrates completely with Houdini 19.5 Solaris.
What is OctaneRender for Solaris?
The OctaneRender for Solaris plugin is based on Pixar’s USD (Universal Scene Description) and Pixar’s Hydra API to empower artist workflows across look development, scene layout, lighting, and final rendering.
Pixar's USD pipeline
https://renderman.pixar.com/stories/pixars-usd-pipeline
- Please note: OctaneSolaris is merged with the latest OctaneRender 2021.1 for Houdini build 2021.1.6.0 for Houdini 19.5.368, so no need to install the main plugin
-Installation steps-
Insert the OctaneRender® plugin folder path to the houdini.env file. Houdini®creates this file after launching it for the first time.
On Linux and macOS® systems, append a single line to enable OctaneRender®:
HOUDINI_PATH = "/path/to/octane;&"
On Windows® systems, you need to set the PATH to point to the plugin bin folder as well:
PATH = "C:/path/to/octane/bin;$PATH"
Setting this environment variable outputs any error related to loading the OctaneRender® plugin on the command line for diagnosing installation problems:
HOUDINI_DSO_ERROR = 2
-Houdnin Packages/json installation steps-
- Please create a folder inside Documents\houdini19.5 and name it as Packages
- Open notepad or any text editor and use these lines
    "enable" : true,
    "env":
        "OCTANE_AUTOSPAREPARAMS" :
            "value": 1,
            //location to your octane folder (example below)
            "OCTVERSION": "PATH\TO\OCTANESOLARIS\Win64FOLDER",
            "HOUDINI_PATH" :
                "value": "$OCTVERSION",
            "PATH" :
                "value": "$OCTVERSION/bin",
            "PXR_PLUGINPATH_NAME" :
                //if you have the solaris version installed
                "value": "$PATH\TO\OCTANESOLARIS\dso\usd_plugins",
- Then Save as OctaneSolaris.json
- Please make sure to disable the .env paths
New features
To learn more about the new features and improvements of OctaneRender 2021.1.5, please check out the 2021.1.1 release post
- Change log since last release[Test]-
  • - Compiled with Houdini production build 2021.1.6.0 for H19.5.368
  • - Improved Octane RenderSettings UIs
  • - Added support for Octane render output (WIP)
  • - Added Octane HDA
Note: click the link below to refer to Important SOP to USD attribute conversion
https://www.sidefx.com/docs/houdini18.5 ... mport.html
-Known Issues-
- Octane Color response is disabled because Hydra buffer expects linear output
- Light Linker is yet to be supported as we are investigating if we could assign the Octane light IDs internally.
However, the usual Octane light linking works as expected.
- Deep AOV is yet to support!
Enterprise Subscription Downloads
2021.1.6 Houdini 19.5.368
Studio Subscription Downloads
Demo build Download
Happy GPU Rendering !!
Your team
OTOY
Kind Regards
bk3d
peteg
Thanks BK! Starting to test this out now
BK
peteg wrote:Thanks BK! Starting to test this out now
Thanks Pete, btw, the Photon tracer in the Kernel menu would work once we build the 2022.1XB!
cheers
Kind Regards
bk3d
peteg
cheers
Looking forward to trying that out!
I ran into an issue with the Octane Material Gradient Tool. Changing the point positions on the ramp doesn't seem to have any effect. I uploaded a screen capture and scene file showing the issue. There's a Karma setup included with the expected behavior.
https://www.dropbox.com/sh/51xz8msasjbr ... oNv1a?dl=0
peteg
Also noticed an issue if the display flag is set to a chain of Karma nodes on startup, Octane will give a "Material not found" error when activated. Restarting the render doesn't seem to help. If the scene starts with the display flag set to the Octane node chain, it works as expected.
Screen recording of the issue and sample file -
https://www.dropbox.com/sh/59a4upagrfox ... h29Pa?dl=0
BK
cheers
Hi Pete,
Thank you so much for the test scene and the video. It is very helpful.
Yes, it seems OctaneHydra Solaris needs a start and an end point in the Ramp.
And to adjust the ramp position we need to add a new point..
would you please try and see if it works?
cheers
Kind Regards
bk3d
BK
peteg wrote:Also noticed an issue if the display flag is set to a chain of Karma nodes on startup, Octane will give a "Material not found" error when activated. Restarting the render doesn't seem to help. If the scene starts with the display flag set to the Octane node chain, it works as expected.
Thank you so much for this again!
Yes, this error is a known issue and we have reported it to SideFX devs.
For now, please exit Houdini, then sign out and sign back into the License manager tool.
cheers
Kind Regards
bk3d
peteg
Hi Pete,
cheers
That works, thanks!
coresign
How to import ORBX file in solaris?
BK
coresign wrote:How to import ORBX file in solaris?
Hi Coresign,
Oh yeah, we have plans to integrate ORBX import/Proxy in future releases!
Cheers
Kind Regards
bk3d
